- To: "" <>
- Subject: RE: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational Kernel
- Date: Sat, 23 Feb 2008 16:11:08 +0800
- Disposition-notification-to: "Max" <>
- Organization: LoadCom
>Hi Stephen,
>I introduced these new items, because it was clear that filtered kernels
Hi Peter,
How are 'filtered' kernels different from 'standard' kernels(besides that you
mentioned here)?
Thanks
Max
>are inefficient with the old ones. The new ones allow efficient
>filtering. Since I mostly wanted to speed up Cartesian kernels and
>therefore allow handling of double coordinates, I write about it at a
>seemingly strange place of the documentation. It's in the user manual
>under File I/O.
>BTW, do you compile with -DNDEBUG and -O2? That usually gives a big
>efficiency boost.
>Peter
- [3d_boolean_ops] Most Efficient Rational Kernel, Stephen Wong, 02/18/2008
- Re: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational Kernel, Max, 02/19/2008
- Re: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational Kernel, Peter Hachenberger, 02/22/2008
- RE: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational Kernel, Stephen Wong, 02/22/2008
- RE: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational Kernel, Peter Hachenberger, 02/22/2008
- RE: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational Kernel, Maarten Moesen, 02/25/2008
- RE: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational Kernel, Max, 02/23/2008
