cgal-discuss - RE: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational Kernel
  • To:
  • Subject: RE: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational Kernel
  • Date: Mon, 25 Feb 2008 09:21:53 +0100
  • Organization: Katholieke Universiteit Leuven
Hello Stephen and Peter,
> I agree with you when you mention that that section in the manual can be
> overlooked.
> Perhaps a separate heading with "Kernel Selection" can provide more insight
> to the user.
Although I'm aware that kernels and their efficiency are prone to
changes, I too think it is a good suggestion to make a separate section
about kernel selection. Why not opening it up to requirements,
limitations and recommendations for kernels and add also what's
mentioned in the reference guide. This may save a user lots of time!
Regards and keep up the good work,
Maarten
> Yes, I have used NDEBUG and O2.
> Stephen
> -----Original Message-----
> From: Peter Hachenberger
> [mailto:]
> Sent: February-22-08 11:39 AM
> To:
> Hi Stephen,
> I introduced these new items, because it was clear that filtered kernels
> are inefficient with the old ones. The new ones allow efficient
> filtering. Since I mostly wanted to speed up Cartesian kernels and
> therefore allow handling of double coordinates, I write about it at a
> seemingly strange place of the documentation. It's in the user manual
> under File I/O.
> BTW, do you compile with -DNDEBUG and -O2? That usually gives a big
> efficiency boost.
> Peter
> On Fri, 2008-02-22 at 11:19 -0800, Stephen Wong wrote:
> > Hi Peter,
> > I didn't use SNC_indexed_items before. I am noticing about 30-40%
> > improvement in computation time (30% faster) after using
> > Exact_constructions_exact_predicates and SNC_indexed_items!
> > What does the indexed items do? It's not mentioned in the documentation
> > - in fact, the current documentation suggests that you should stay with
> > the default, SNC_items.
> > Thanks for your excellent analysis.
> > Stephen
> > [mailto:]
> > Sent: February-22-08 4:14 AM
> > To:
> > Subject: Re: [cgal-discuss] [3d_boolean_ops] Most Efficient Rational
> > Kernel
> > Hi Stephen,
> > I performed some tests. Assuming you have gmp but no leda, the
> > Exact_predicate_exact_constructions_kernel is up to double as fast as
> > all the others. Don't forget to use the SNC_indexed_items with that
> > kernel. Also all the other kernels (besides the extended kernels) profit
> > from the SNC_indexed_items. The second fastest seems to be
> > Simple_cartesian<Gmpq>. The homogeneous kernels were in general slower
> > than the Cartesians. That would be different with LEDA.
> > Homogeneous<leda_integer> is very fast.
> > Peter
> > On Mon, 2008-02-18 at 11:38 -0800, Stephen Wong wrote:
> > > Hi there,
> > > I am wondering what is the most computationally-efficient kernel that
> > > is allowable in Nef Polyhedra in 3D (Boolean operations), in the set
> > > of rational numbers Q. Right now I am using Cartesian<Gmpq>, a
> > > variant of Exact_predicate_exact_constructions_kernel. I am wondering
> > > if there is a Kernel (than I have stated) that performs more
> > > efficiently. If not, is there a more efficient number type than Gmpq
> > > that is compatible with 3D Nef Polyhedra?
> > > On the same topic of discussion, if I were to use kernels representing
> > > Z, which is the most efficient kernel?
> > > Thanks,
> > > Stephen
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
ir. Maarten Moesen
Department of Metallurgy and Materials Engineering (MTM)
K.U.Leuven
Kasteelpark Arenberg 44 - Bus 02450
B-3001 Heverlee, Belgium
tel. +32 (0)16 32 13 17
fax. +32 (0)16 32 19 90
Disclaimer: http://www.kuleuven.be/cwis/email_disclaimer.htm
