- To:
- Subject: Re: [cgal-discuss] CGAL (need help writing the facets to a file)
- Date: Sun, 09 Mar 2008 11:44:24 +0100
Hi Santosh,
Santosh Tiwari wrote:
Hello,The triangulation data structure stores facets only implicitly:
I am learning to use CGAL.
I want to output the vertices of a list of Facets on the screen. How do I do
it?
Any help or references would be appreciated. Following is the code snippet,
I am using.
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/TriangulationDS_3/Chapter_main.html
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/TriangulationDS_3_ref/Concept_TriangulationDataStructure_3.html
Short explanation:
A facet is represented as a pair of a Cell_handle ch of a cell to which the facet is incident and an int i such that ch->vertex(i) gives you the only vertex that is not incident to the facet (the opposite vertex).
To output the all vertices of the facet f you could do something like
std::cout<<f.first->vertex((f.second+1)%4)<<", "
<<f.first->vertex((f.second+2)%4)<<", "
<<f.first->vertex((f.second+3)%4)<<std::endl;
Best
Manuel
- CGAL (need help writing the facets to a file), Santosh Tiwari, 03/09/2008
- Re: [cgal-discuss] CGAL (need help writing the facets to a file), Manuel Caroli, 03/09/2008
- RE: [cgal-discuss] CGAL (need help writing the facets to a file), Santosh Tiwari, 03/09/2008
- CGAL (Error message), Santosh Tiwari, 03/10/2008
- Re: [cgal-discuss] CGAL (need help writing the facets to a file), Andreas Fabri, 03/10/2008
- RE: [cgal-discuss] CGAL (need help writing the facets to a file), Santosh Tiwari, 03/13/2008
- CGAL (need suggestion for surface mesh refinement), Santosh Tiwari, 03/13/2008
