- To: <>
- Subject: RE: [cgal-discuss] CGAL (need help writing the facets to a file)
- Date: Sun, 9 Mar 2008 15:42:30 -0400
- Organization: Clemson University
Thanks a lot.
I am able to write the facets now. I am using the following code snippet.
//write the facets;
list<Facet> facets;
as.get_alpha_shape_facets(back_inserter(facets),
Alpha_shape_3::REGULAR);
cout<<facets.size()<<" boundary facets \n";
int numFacets = 0;
for(list<Facet>::const_iterator iter = facets.begin();
iter!=facets.end(); ++iter) {
cout<<"Facet "<<++numFacets<<endl;
cout<<(*(iter->first->vertex(1))).point()<<", ";
cout<<(*(iter->first->vertex(2))).point()<<", ";
cout<<(*(iter->first->vertex(3))).point()<<endl;
Thanks again. :)
__
Santosh Tiwari
-----Original Message-----
[mailto:]
Sent: Sunday, March 09, 2008 6:44 AM
To:
Subject: Re: [cgal-discuss] CGAL (need help writing the facets to a file)
Hi Santosh,
Santosh Tiwari wrote:
> Hello,
> I am learning to use CGAL.
> I want to output the vertices of a list of Facets on the screen. How do I
do
> it?
> Any help or references would be appreciated. Following is the code
snippet,
> I am using.
The triangulation data structure stores facets only implicitly:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/TriangulationDS_3/Chapte
r_main.html
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/TriangulationDS_3_ref/Co
ncept_TriangulationDataStructure_3.html
Short explanation:
A facet is represented as a pair of a Cell_handle ch of a cell to which
the facet is incident and an int i such that ch->vertex(i) gives you the
only vertex that is not incident to the facet (the opposite vertex).
To output the all vertices of the facet f you could do something like
std::cout<<f.first->vertex((f.second+1)%4)<<", "
<<f.first->vertex((f.second+2)%4)<<", "
<<f.first->vertex((f.second+3)%4)<<std::endl;
Best
Manuel
- CGAL (need help writing the facets to a file), Santosh Tiwari, 03/09/2008
- Re: [cgal-discuss] CGAL (need help writing the facets to a file), Manuel Caroli, 03/09/2008
- RE: [cgal-discuss] CGAL (need help writing the facets to a file), Santosh Tiwari, 03/09/2008
- CGAL (Error message), Santosh Tiwari, 03/10/2008
- Re: [cgal-discuss] CGAL (need help writing the facets to a file), Andreas Fabri, 03/10/2008
- RE: [cgal-discuss] CGAL (need help writing the facets to a file), Santosh Tiwari, 03/13/2008
- CGAL (need suggestion for surface mesh refinement), Santosh Tiwari, 03/13/2008
