cgal-discuss - RE: [cgal-discuss] CGAL (need help writing the facets to a file)
  • To: <>
  • Subject: RE: [cgal-discuss] CGAL (need help writing the facets to a file)
  • Date: Wed, 12 Mar 2008 22:09:06 -0400
  • Organization: Clemson University
Thanks a lot for the help. I am now able to get correct surface normals for
arbitrarily complex models.
__
Santosh Tiwari
EIB-326 Clemson University
http://www.clemson.edu/~stiwari/
-----Original Message-----
[mailto:]
Sent: Monday, March 10, 2008 3:54 AM
To:
Subject: Re: [cgal-discuss] CGAL (need help writing the facets to a file)
Hi Santosh,
You might have a look at this helper class, which is the base class of the
3D triangulation classes,
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/TriangulationDS_3_ref/Cl
ass_Triangulation_utils_3.html#Cross_link_anchor_994
andreas
Santosh Tiwari wrote:
> I had to modify the code as suggested in the previous mail to get the
> correct list of vertices.
> x1 = (*(iter->first->vertex((iter->second+1)%4))).point().x();
> y1 = (*(iter->first->vertex((iter->second+1)%4))).point().y();
> z1 = (*(iter->first->vertex((iter->second+1)%4))).point().z();
> x2 = (*(iter->first->vertex((iter->second+2)%4))).point().x();
> y2 = (*(iter->first->vertex((iter->second+2)%4))).point().y();
> z2 = (*(iter->first->vertex((iter->second+2)%4))).point().z();
> x3 = (*(iter->first->vertex((iter->second+3)%4))).point().x();
> y3 = (*(iter->first->vertex((iter->second+3)%4))).point().y();
> z3 = (*(iter->first->vertex((iter->second+3)%4))).point().z();
> I have a few questions.
> How do I know what is the correct CCW direction for the nodes, such that
the
> facet normal points outside?
> Some of the triangles seem wrong (I can post the snapshot of the original
> object and the obtained object if desired).
> Thanks again.
> __
> Santosh Tiwari
> From: Santosh Tiwari
> [mailto:]
> Sent: Sunday, March 09, 2008 3:43 PM
> To:
> Thanks a lot.
> I am able to write the facets now. I am using the following code snippet.
> //write the facets;
> list<Facet> facets;
> as.get_alpha_shape_facets(back_inserter(facets),
> Alpha_shape_3::REGULAR);
> cout<<facets.size()<<" boundary facets \n";
> int numFacets = 0;
> for(list<Facet>::const_iterator iter = facets.begin();
> iter!=facets.end(); ++iter) {
> cout<<"Facet "<<++numFacets<<endl;
> cout<<(*(iter->first->vertex(1))).point()<<", ";
> cout<<(*(iter->first->vertex(2))).point()<<", ";
> cout<<(*(iter->first->vertex(3))).point()<<endl;
> Thanks again. :)
> __
> Santosh Tiwari
> From: Manuel Caroli
> [mailto:]
> Sent: Sunday, March 09, 2008 6:44 AM
> To:
> Hi Santosh,
>> Hello,
>> I am learning to use CGAL.
>> I want to output the vertices of a list of Facets on the screen. How do I
> do
>> it?
>> Any help or references would be appreciated. Following is the code
> snippet,
>> I am using.
> The triangulation data structure stores facets only implicitly:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/TriangulationDS_3/Chapte
> r_main.html
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/TriangulationDS_3_ref/Co
> ncept_TriangulationDataStructure_3.html
> Short explanation:
> A facet is represented as a pair of a Cell_handle ch of a cell to which
> the facet is incident and an int i such that ch->vertex(i) gives you the
> only vertex that is not incident to the facet (the opposite vertex).
> To output the all vertices of the facet f you could do something like
> std::cout<<f.first->vertex((f.second+1)%4)<<", "
> <<f.first->vertex((f.second+2)%4)<<", "
> <<f.first->vertex((f.second+3)%4)<<std::endl;
> Best
> Manuel
