cgal-discuss - Triangulation 2 data structure problem
  • To: <>
  • Subject: Triangulation 2 data structure problem
  • Date: Tue, 25 Mar 2008 03:43:37 -0700
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=from:to:subject:date:mime-version:content-type:content-transfer-encoding:x-mailer:thread-index:content-language:message-id; b=c2LW/yBbx++xwVJhr+kO+c5PRFCFBFa983LYmJhpS5cKP/Msz6RIS4aKvJu9zdo+fgH/9xhQFWMOIzwWH/lyFH6EE7f04FrWXTptD4+/nn9/eSsEwzq9HXePdJCKNnSLYtSANKYjLTTOp6trjo+1U1Ni45TM09MlROaXt19E7ok=
Hello,
I'm trying to construct a 2D triangle mesh from a list of vertices and
faces. I didn't want to use Polyhedron because I needed some properties from
the 2D triangulation class. I'm using Triangulation_2 and
Triangulation_data_structure_2. Basically I use T.tds() to get a reference
to the internal data structure. Then I add vertices and faces to it. But
this has become very confusing and I couldn't find examples on this.
An outline of my code:
triDS.set_dimension(2);
for(...) {
VertexHandle vHandle = triDS.create_vertex();
vHandle->set_point(Point2(...));
for(...) {
FaceHandle fHandle = triDS.create_face(vHandle1, vHandle2, vHandle3); }
When I check triDS.is_valid() at the end, it returns false. More
interestingly, before I add anything to triDS, when I check the vertices,
edge, etc. I get this
Triangulation vertices: 0
Triangulation faces: 1
Triangulation full faces: 1
Triangulation edges: 1
So am I suppose to clear this before I add something to it? Looking at the
template file for the data structure, it check this:
case 2:
result = result && edge_count == 3*face_count/2 ;
CGAL_triangulation_assertion(edge_count == 3*face_count/2);
break;
I'm not sure what the expected behavior is. Could someone tell me what I'm
doing wrong and how this class suppose to be used? Thanks!
Louis
