cgal-discuss - Re: [cgal-discuss] fix border edges for mesh simplification
  • To: <>
  • Subject: Re: [cgal-discuss] fix border edges for mesh simplification
  • Date: Fri, 28 Mar 2008 19:17:21 -0300
  • Organization: Geometry Factory
Hi Qianqian,
The reason this doesn't just work is that border edges are not collapsed per-se but those non-border edges adjacent to the border vertices are, so the border vertices are moved.
One way to do what you need is via a placement policy wrapper whicch would return boost:::none for any edge adjacent to a border vertex.
Here's an example off the top of my head:
template<class GetPlacement_>
struct Placement_with_fixed_border_vertices : GetPlacement_
typedef GetPlacement_ GetPlacement ;
typedef typename GetPlacement::Profile Profile ;
typedef typename GetPlacement::result_type result_type ;
result_type operator()( Profile const& aProfile ) const
if ( is_border_vertex(aProfile.v0()) || is_border_vertex(aProfile.v1()) )
return boost::none ;
else
return this->GetPlacement::operator()(aProfile);
bool is_border_vertex( typename Profile::const_vertex_descriptor v )
// whatever works for you enriched polyhedron, i.e.: true if any adjacent halfedge is a border.
HTH
Fernando Cacciola
GeometryFactory
