- To:
- Subject: Re: [cgal-discuss] fix border edges for mesh simplification
- Date: Sun, 30 Mar 2008 11:28:54 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=pvCd7rgT4sVJIbWzizE8D5cvTr8gnDV0eQLe7EyPpiV1vmYu6y5kTr06qZnogBjKGdn0PtwSjxhH687zsphRmuy2niCXQI7gUIi3hzgkMkj/0D2yUp07G26CG62lBXcfn7AfYUkZ2GnNGx4ilhFKeKv2A+hd0a+b5gY/ZP3RuBs=
hi Fernando
thank you very much for the quick response. The explanations make sense to me.
Now I am trying to hook the Placement_with_fixed_border_vertices policy to
the edge_collapse() call. I have some difficulty to figure out where to insert
the code.
The original edge_collapse() in
example/Surface_mesh_simplification/edge_collapse_enriched_polyhedron.cpp
looks like the following:
int r = SMS::edge_collapse
(surface
,stop
,CGAL::get_cost (SMS::Edge_length_cost <Surface>())
.get_placement(SMS::Midpoint_placement<Surface>())
.visitor(&vis)
I assumed the 3rd parameter sets cost policy, sets the placement policy and
sets a visitor. Can you enlighten me what the 3rd parameter should look like
if I want to use the Placement_with_fixed_border_vertices policy instead?
in addition, I found in "include/CGAL/Surface_mesh_simplification/Detail/Edge_collapse.h"
a function called is_border( const_vertex_descriptor const& aV), is it correct to
write
return is_border(v);
inside your is_border_vertex().
I guess I can spend another couple of hours to figure out these eventually,
but if you can guide me on these key concepts, even briefly, that will save
a great deal of my efforts, I really appreciate for your help.
Qianqian
On Fri, Mar 28, 2008 at 6:17 PM, Fernando Cacciola <> wrote:
Hi Qianqian,
The reason this doesn't just work is that border edges are not collapsed per-se
but those non-border edges adjacent to the border vertices are, so the border
vertices are moved.
One way to do what you need is via a placement policy wrapper whicch would
return boost:::none for any edge adjacent to a border vertex.
Here's an example off the top of my head:
template<class GetPlacement_>
struct Placement_with_fixed_border_vertices : GetPlacement_
typedef GetPlacement_ GetPlacement ;
typedef typename GetPlacement::Profile Profile ;
typedef typename GetPlacement::result_type result_type ;
result_type operator()( Profile const& aProfile ) const
if ( is_border_vertex(aProfile.v0()) || is_border_vertex(aProfile.v1()) )
return boost::none ;
else
return this->GetPlacement::operator()(aProfile);
bool is_border_vertex( typename Profile::const_vertex_descriptor v )
// whatever works for you enriched polyhedron, i.e.: true if any adjacent
halfedge is a border.
HTH
Fernando Cacciola
GeometryFactory
- fix border edges for mesh simplification, Qianqian Fang, 03/28/2008
- Re: [cgal-discuss] fix border edges for mesh simplification, Fernando Cacciola, 03/28/2008
- Re: [cgal-discuss] fix border edges for mesh simplification, Qianqian Fang, 03/30/2008
- Re: [cgal-discuss] fix border edges for mesh simplification, Fernando Cacciola, 03/31/2008
- Re: [cgal-discuss] fix border edges for mesh simplification, Qianqian Fang, 03/31/2008
