- To:
- Subject: Re: [cgal-discuss] fix border edges for mesh simplification
- Date: Mon, 31 Mar 2008 15:33:10 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=EwYQPKPVXWrFOEDDMMoTacB9kboxU6VjT73FFllAoxeIOTCXsku6nuWAMBx+e+Hqs5K/HnZyomeQJhQhnSjTsgjclB2Ja7p50AQ2OUYMG3pBwlf4HAR2JZhmgVu1INcQf61W1C7UZ147ml0mkws2vjtcyllWGlXAoloSYPyqu4I=
hi Fernando
thank you very much for the code. I have played with for a little while, now I stuck at
the definition of "const_in_edge_iterator" used in is_border_vertex().
the error message is:
edge_collapse_enriched_polyhedron.cpp:126: error: no type named 'const_in_edge_iterator' in 'class CGAL::Surface_mesh_simplification::Edge_profile<CGAL::Polyhedron_3<CGAL::Simple_cartesian<double>, CGAL::Polyhedron_items_with_id_3, CGAL::HalfedgeDS_default, std::allocator<int> > >'
indeed, I inserted a typedef line for this iterator type inside the class, however, it does not seems
to match the required types.
My modified class is listed below, and the full unit is also attached. Do I need to
include other units in order to get the proper namespace path for this type?
I really appreciate your time for helping me on this and apologize for all the
troubles, I have not seriously done programming with templates.
it does take a while for me to fully digest the structure of the library.
Qianqian
template<class GetPlacement_>
struct Placement_with_fixed_border_vertices : GetPlacement_
typedef GetPlacement_ GetPlacement ;
typedef typename GetPlacement::Profile Profile ;
typedef typename GetPlacement::result_type result_type ;
typedef typename Profile::const_vertex_descriptor const_vertex_descriptor ;
typedef typename Profile::const_edge_descriptor const_edge_descriptor ;
typedef typename Profile::const_in_edge_iterator const_in_edge_iterator ;
result_type operator()( Profile const& aProfile ) const
if ( is_border_vertex(aProfile,aProfile.v0()) || is_border_vertex(aProfile,aProfile.v1()) )
return boost::none ;
else{
return this->GetPlacement::operator()(aProfile);
bool is_border_vertex( Profile const& aProfile, const_vertex_descriptor v ) const
bool rR = false ;
const_in_edge_iterator eb, ee ;
for ( boost::tie(eb,ee) = boost::in_edges(v,aProfile.surface()) ; eb != ee ; ++ eb )
const_in_edge_iterator lEdge = *eb ;
if ( lEdge->is_border() || lEdge->opposite()->is_border() )
rR = true ;
break ;
return rR ;
On Mon, Mar 31, 2008 at 8:47 AM, Fernando Cacciola <> wrote:
Hi Qianqian,
That's correct.
> hi Fernando
> thank you very much for the quick response. The explanations make sense to
> me.
> Now I am trying to hook the Placement_with_fixed_border_vertices policy to
> the edge_collapse() call. I have some difficulty to figure out where to
> insert
> the code.
> The original edge_collapse() in
> example/Surface_mesh_simplification/edge_collapse_enriched_polyhedron.cpp
> looks like the following:
> int r = SMS::edge_collapse
> (surface
> ,stop
> ,CGAL::get_cost (SMS::Edge_length_cost <Surface>())
> .get_placement(SMS::Midpoint_placement<Surface>())
> .visitor(&vis)
> I assumed the 3rd parameter sets cost policy, sets the placement policy and
> sets a visitor.
OK.
> Can you enlighten me what the 3rd parameter should look like
> if I want to use the Placement_with_fixed_border_vertices policy instead?
First add this typedef before main():
typedef Placement_with_fixed_border_vertices< SMS::Midpoint_placement<Surface> >
My_placement ;
then use it like this:
.get_placement( My_placement() )
(surface
,stop
.visitor(&vis)
Unfortunately that function is a private method of the EdgeCollapse class so you
> in addition, I found in
> "include/CGAL/Surface_mesh_simplification/Detail/Edge_collapse.h"
> a function called is_border( const_vertex_descriptor const& aV), is it
> correct to
> write
> return is_border(v);
> inside your is_border_vertex().
cannot call that it from within the policy.
OTOH, you can "borrow" it's implementation, as in the attached file (NOTE:
That's is off the top of my head, I haven't compiled nor tested it)
HTH
Fernando Cacciola
GeometryFactory
Description: Binary data
- fix border edges for mesh simplification, Qianqian Fang, 03/28/2008
- Re: [cgal-discuss] fix border edges for mesh simplification, Fernando Cacciola, 03/28/2008
- Re: [cgal-discuss] fix border edges for mesh simplification, Qianqian Fang, 03/30/2008
- Re: [cgal-discuss] fix border edges for mesh simplification, Fernando Cacciola, 03/31/2008
- Re: [cgal-discuss] fix border edges for mesh simplification, Qianqian Fang, 03/31/2008
