- To:
- Subject: Convex Decomposition of Polyhedron inside CGAL or elsewhere?
- Date: Tue, 01 Apr 2008 16:25:27 +0200
Hello,
I'm a student working on a computer game project at the university. I'm currently working on collision geometry. Computing the convex hulls of the point clouds of our vehicle models proved to be insufficient. And to keep things simple for the artists I thought the following might be the way to go.
The artist builds a concave, closed polyhedron and runs a program that computes the convex decomposition of the polyhedron. The resulting convex polyhedra can then directly be handled by the physics engine. Or if the artist would like to do so, he can decrease the amount of the convex polyhedra by computing a common convex hull for two or more of them. For the last step, I can easily use CGAL functionality.
The problem is the convex decomposition. Is there an algorithm or library that computes the convex decomposition for a closed polyhedron? Since it is not necessary to compute the optimal solution, I thought there might be something like the Greene's approximation for 3D? As such computations are only performed once on every model, the running time and memory consumption can be quite high. Meaning the program could use up to 4GB of RAM and run for 30 minutes on a current high-end consumer processor with an input polyhedron with 20.000 vertices.
Is there such an algorithm, maybe even inside CGAL? Or could you provide me with some information on that matter? Unfortunately, Google wasn't very helpful on this issue for me. Please excuse my possible lack of knowledge about the theory behind this computational problem.
Regards
Maik Schulze
- Convex Decomposition of Polyhedron inside CGAL or elsewhere?, Maik Schulze, 04/01/2008
- RE: [cgal-discuss] Convex Decomposition of Polyhedron inside CGAL or elsewhere?, David Lariviere, 04/01/2008
- Re: [cgal-discuss] Convex Decomposition of Polyhedron inside CGAL or elsewhere?, Maik Schulze, 04/04/2008
- Re: [cgal-discuss] Convex Decomposition of Polyhedron inside CGAL or elsewhere?, Peter Hachenberger, 04/02/2008
- RE: [cgal-discuss] Convex Decomposition of Polyhedron inside CGALor elsewhere?, David Lariviere, 04/02/2008
- RE: [cgal-discuss] Convex Decomposition of Polyhedron inside CGALor elsewhere?, Peter Hachenberger, 04/02/2008
