RE: [cgal-discuss] Convex Decomposition of Polyhedron inside CGAL or elsewhere?
- To: <>, "'Maik Schulze'" <>
- Subject: RE: [cgal-discuss] Convex Decomposition of Polyhedron inside CGAL or elsewhere?
- Date: Tue, 1 Apr 2008 10:59:18 -0400
Hi Maik,
One academic work on this problem is Lien and Amato's Approximate Convex
Decomposition (see http://www.cs.gmu.edu/~jmlien/research/app-cd/ ). While
the 2D binaries are provided, the 3D version is not yet released.
I've been trying to implement ACD using CGAL for the last 5 months, but have
been struggling with it, a lot of which has been related to restrictions on
the meshes within Polyhedron_3.
The only open source implementation related is John Ratcliff's method (see
http://codesuppository.blogspot.com/2006/04/approximate-convex-decomposition
.html ), designed with similar applications in mind. He initially set out to
implement ACD as described by Lien and Amato as well, but eventually
utilized a simpler method of first iteratively splitting meshes using the
longest edge of an oriented bounding box until the concavity measure is
below some threshold, and then applying a post processing algorithm to
restitch nearby pieces.
If I ever get my CGAL-based implementation working, I'll drop you a note.
- David
-----Original Message-----
[mailto:]
Sent: Tuesday, April 01, 2008 10:25 AM
To:
Subject: [cgal-discuss] Convex Decomposition of Polyhedron inside CGAL or
elsewhere?
Hello,
I'm a student working on a computer game project at the university. I'm
currently working on collision geometry. Computing the convex hulls of
the point clouds of our vehicle models proved to be insufficient. And to
keep things simple for the artists I thought the following might be the
way to go.
The artist builds a concave, closed polyhedron and runs a program that
computes the convex decomposition of the polyhedron. The resulting
convex polyhedra can then directly be handled by the physics engine. Or
if the artist would like to do so, he can decrease the amount of the
convex polyhedra by computing a common convex hull for two or more of
them. For the last step, I can easily use CGAL functionality.
The problem is the convex decomposition. Is there an algorithm or
library that computes the convex decomposition for a closed polyhedron?
Since it is not necessary to compute the optimal solution, I thought
there might be something like the Greene's approximation for 3D? As such
computations are only performed once on every model, the running time
and memory consumption can be quite high. Meaning the program could use
up to 4GB of RAM and run for 30 minutes on a current high-end consumer
processor with an input polyhedron with 20.000 vertices.
Is there such an algorithm, maybe even inside CGAL? Or could you provide
me with some information on that matter? Unfortunately, Google wasn't
very helpful on this issue for me. Please excuse my possible lack of
knowledge about the theory behind this computational problem.
Regards
Maik Schulze
- Convex Decomposition of Polyhedron inside CGAL or elsewhere?, Maik Schulze, 04/01/2008
- RE: [cgal-discuss] Convex Decomposition of Polyhedron inside CGAL or elsewhere?, David Lariviere, 04/01/2008
- Re: [cgal-discuss] Convex Decomposition of Polyhedron inside CGAL or elsewhere?, Maik Schulze, 04/04/2008
- Re: [cgal-discuss] Convex Decomposition of Polyhedron inside CGAL or elsewhere?, Peter Hachenberger, 04/02/2008
- RE: [cgal-discuss] Convex Decomposition of Polyhedron inside CGALor elsewhere?, David Lariviere, 04/02/2008
- RE: [cgal-discuss] Convex Decomposition of Polyhedron inside CGALor elsewhere?, Peter Hachenberger, 04/02/2008
