Re: [cgal-discuss] Convex Decomposition of Polyhedron inside CGAL or elsewhere?
- To:
- Subject: Re: [cgal-discuss] Convex Decomposition of Polyhedron inside CGAL or elsewhere?
- Date: Wed, 02 Apr 2008 14:05:07 +0200
Hi Maik,
I have exactly what you want, but it's not in CGAL, yet. It's working
nicely and is scheduled for the next CGAL release. I guess that is a bit
late for you.
Peter
On Tue, 2008-04-01 at 16:25 +0200, Maik Schulze wrote:
> Hello,
> I'm a student working on a computer game project at the university. I'm
> currently working on collision geometry. Computing the convex hulls of
> the point clouds of our vehicle models proved to be insufficient. And to
> keep things simple for the artists I thought the following might be the
> way to go.
> The artist builds a concave, closed polyhedron and runs a program that
> computes the convex decomposition of the polyhedron. The resulting
> convex polyhedra can then directly be handled by the physics engine. Or
> if the artist would like to do so, he can decrease the amount of the
> convex polyhedra by computing a common convex hull for two or more of
> them. For the last step, I can easily use CGAL functionality.
> The problem is the convex decomposition. Is there an algorithm or
> library that computes the convex decomposition for a closed polyhedron?
> Since it is not necessary to compute the optimal solution, I thought
> there might be something like the Greene's approximation for 3D? As such
> computations are only performed once on every model, the running time
> and memory consumption can be quite high. Meaning the program could use
> up to 4GB of RAM and run for 30 minutes on a current high-end consumer
> processor with an input polyhedron with 20.000 vertices.
> Is there such an algorithm, maybe even inside CGAL? Or could you provide
> me with some information on that matter? Unfortunately, Google wasn't
> very helpful on this issue for me. Please excuse my possible lack of
> knowledge about the theory behind this computational problem.
> Regards
> Maik Schulze
- Convex Decomposition of Polyhedron inside CGAL or elsewhere?, Maik Schulze, 04/01/2008
- RE: [cgal-discuss] Convex Decomposition of Polyhedron inside CGAL or elsewhere?, David Lariviere, 04/01/2008
- Re: [cgal-discuss] Convex Decomposition of Polyhedron inside CGAL or elsewhere?, Maik Schulze, 04/04/2008
- Re: [cgal-discuss] Convex Decomposition of Polyhedron inside CGAL or elsewhere?, Peter Hachenberger, 04/02/2008
- RE: [cgal-discuss] Convex Decomposition of Polyhedron inside CGALor elsewhere?, David Lariviere, 04/02/2008
- RE: [cgal-discuss] Convex Decomposition of Polyhedron inside CGALor elsewhere?, Peter Hachenberger, 04/02/2008
