- To: <>
- Subject: Re: [cgal-discuss] fix border edges for mesh simplification
- Date: Thu, 3 Apr 2008 10:11:11 -0300
- Organization: Geometry Factory
Hi Qianqian,
thank you FernandoI'm afraid I would have to investigate this further but I can't do that now.
Now the code compiles normally. Unfortunately, the simplified surface mesh
is similar to the
old one:some of the border edges were collapsed.
[SNIP]
I don't want to spend too much of your time on this, but if you have some
quick
thoughts or ideas where to look at, that would be great help.
The only idea I can give you at this point is to wrap the GetCost function to prevent collpasing any edge adjacent to a border edge:
template<class GetCost_>
struct Cost_with_fixed_edges : GetCost_
typedef GetCost_ GetCost ;
typedef typename GetCost::Profile Profile ;
typedef typename GetCost::Point Point ;
typedef typename GetCost::result_type result_type ;
result_type operator()( Profile const& aProfile, boost::optional<Point> const& aPlacement ) const
if ( aProfile.border_edges().size() > 0 )
return boost::none ;
else
return this->GetCost::operator()(aProfile, aPlacement);
typedef Cost_with_fixed_edges< SMS::Edge_length_cost<Surface> > My_cost ;
int r = SMS::edge_collapse
(surface
,stop
,CGAL::vertex_index_map(boost::get(CGAL::vertex_external_index,surface))
.edge_index_map (boost::get(CGAL::edge_external_index ,surface))
.get_cost (My_cost())
.get_placement (SMS::Midpoint_placement<Surface>())
HTH
Fernando Cacciola
GeometryFactory
- Re: [cgal-discuss] fix border edges for mesh simplification, Fernando Cacciola, 04/01/2008
- Re: [cgal-discuss] fix border edges for mesh simplification, Qianqian Fang, 04/01/2008
- Re: [cgal-discuss] fix border edges for mesh simplification, Fernando Cacciola, 04/03/2008
- Re: [cgal-discuss] fix border edges for mesh simplification, Qianqian Fang, 04/06/2008
