cgal-discuss - Re: [cgal-discuss] fix border edges for mesh simplification
  • To: <>
  • Subject: Re: [cgal-discuss] fix border edges for mesh simplification
  • Date: Tue, 1 Apr 2008 12:33:54 -0300
  • Organization: Geometry Factory
Hi Qianqian,
Fernando Cacciola wrote:
Hi Qianqian,
typedef typename Profile::const_in_edge_iterator
const_in_edge_iterator ;
Replacing the above line to
typedef typename Profile::ConstGraphTraits::const_in_edge_iterator
the error message became:
edge_collapse_enriched_polyhedron.cpp:142: error: no type named
‘const_in_edge_iterator’ in ‘struct boost::graph_traits<const
CGAL::Polyhedron_3<CGAL::Simple_cartesian<double>,
CGAL::Polyhedron_items_with_id_3, CGAL::HalfedgeDS_default,
std::allocator<int> > >’
seems something still not quite right.
OK...
I couldn't compile the warpper myself because the development version of the package was broken and I had been postponing fixing it until I finish something else.
But now I just fixed it, so I was able to try the wrapper myself...
There were some additional errors, but the attached version works AFAICT.
Best
Fernando Cacciola
GeometryFactory
template<class GetPlacement_>
struct Placement_with_fixed_border_vertices : GetPlacement_
typedef GetPlacement_ GetPlacement ;
typedef typename GetPlacement::Profile Profile ;
typedef typename GetPlacement::result_type result_type ;
typedef typename Profile::ECM ECM ;
typedef typename Profile::const_vertex_descriptor const_vertex_descriptor ;
typedef typename Profile::const_edge_descriptor const_edge_descriptor ;
typedef typename Profile::ConstGraphTraits::in_edge_iterator const_in_edge_iterator ;
result_type operator()( Profile const& aProfile ) const
if ( is_border_vertex(aProfile.v0(), aProfile.surface()) ||
is_border_vertex(aProfile.v1(), aProfile.surface()) )
return boost::none ;
else
return this->GetPlacement::operator()(aProfile);
bool is_border_vertex( const_vertex_descriptor v, ECM& aSurface ) const
bool rR = false ;
const_in_edge_iterator eb, ee ; for ( boost::tie(eb,ee) = boost::in_edges(v,aSurface) ; eb != ee ; ++ eb )
const_edge_descriptor lEdge = *eb ;
if ( lEdge->is_border() || lEdge->opposite()->is_border() )
rR = true ;
break ;
return rR ; }
