- To:
- Subject: Mesh Simlification
- Date: Fri, 4 Apr 2008 15:42:22 +0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:mime-version:content-type; b=ilpTeF+KV/rw/6euWYNrjGgtYguLU37j8u+4aR1Otkj9ZpgsOhV2XcxZWsb9mjQVgvExwf/Lc/nl2dMBZDeywuSRJZbLNNQNv6PpK+D8U6kTut4jL+Rg2pMLkl6h503CvAlpElcWUVJdCI0SKuzBD8+3P8VRUZmnrHskzAERBfs=
Hi again,
I am trying to use "CGAL-3.3.1\examples\Surface_mesh_simplification" example. While it works for "cube.off" file it does not work
for another "xxx.off". For example I have a skull.off file and in the main function I have tried this
Surface surface;
std::ifstream is("skull.off") ;
is >> surface ;
std::ofstream out("output.off");
out<<surface;
The output in the output.off file
OFF
0 0 0
I could not understand the reason. Can anybody help me, if there is someone who had this problem before.
Note: skull.off file is in the attachment.
skull.off
Description: Binary data
- Mesh Simlification, sinan mutlu, 04/04/2008
- Re: [cgal-discuss] Mesh Simlification, Andreas Fabri, 04/04/2008
- Re: [cgal-discuss] Mesh Simlification, sinan mutlu, 04/04/2008
- Re: [cgal-discuss] Mesh Simlification, Laurent Rineau, 04/04/2008
- Re: [cgal-discuss] Mesh Simlification, Pierre Alliez, 04/04/2008
- Re: [cgal-discuss] Mesh Simlification, Sylvain Pion, 04/04/2008
- RE: [cgal-discuss] Mesh Simlification, David Lariviere, 04/04/2008
- Re: [cgal-discuss] Mesh Simlification, Laurent Rineau, 04/06/2008
- Re: [cgal-discuss] Mesh Simlification, Fernando Cacciola, 04/04/2008
