cgal-discuss - Re: [cgal-discuss] Mesh Simlification
  • To:
  • Subject: Re: [cgal-discuss] Mesh Simlification
  • Date: Fri, 4 Apr 2008 16:18:54 +0300
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=ntvGOoMwJUIRfAbrq4vuJ4osiTNNVuhRwdI9ojtvd83CvLyuvmo3Rq1lVD3ydPpRUwuPcf8z+aTmTr+f9l9cVbD/1lTiXjVXBiyszCbWRyknEWjiU1FISL82+Unpbymd0x2MSHLkcLwTy5HSEJ7iPvXd6XKxoO2ORwRPG9ZhMk0=
Dear Andread Fabri,
I have tried the code below:
   Surface surface;
    float maxface=0.1;
    std::ifstream is("cow.off") ;   //std::ifstream is("skull.off") ;
    is >> surface ;
   Surface::Point_iterator pn = surface.points_begin();
    int i = 0;
    while(pn!=surface.points_end())
        i++;
    std::cout<<i<<endl;
and the result is "0".
I do not know much about the library. Maybe I have done wrong things. I guess it reads nothing from the file.
Thank you for your time and consideration.
Sinan
On 04/04/2008, Andreas Fabri <> wrote:
sinan mutlu wrote:
Hi again,
I am trying to use "CGAL-3.3.1\examples\Surface_mesh_simplification" example. While it works for "cube.off" file it does not work
for another "xxx.off". For example I have a skull.off file and in the main function I have tried this
Surface surface;
is >> surface ;
Hi Sinan,
Can you check here, that you really have read something.
Just print surface.number_of_vertices() or something similar.
andreas
std::ofstream out("output.off");
out<<surface;
The output in the output.off file
OFF
0 0 0
I could not understand the reason. Can anybody help me, if there is someone who had this problem before.
Note: skull.off file is in the attachment.
