- To:
- Subject: Re: [cgal-discuss] Mesh Simlification
- Date: Sun, 6 Apr 2008 23:22:49 +0200
- Organization: Inria, Sophia Antipolis, FRANCE
On Friday 04 April 2008 16:17:29 sinan mutlu wrote:
> Dear Laurent Rineau,
> You are right. In the "assert(is.good());" line the example explodes.
> It seems that the file is not read correctly.
> But why it occurs, I have copied the data from "cube.off" into "cow.off"
> and it worked. But what is the differences between these files.
> I have controlled insides of these. Moreover I can open cow.off file with
> different 3D viewers.
Most probably your OFF file cannot be inputted to a CGAL polyhedron.
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
- Mesh Simlification, sinan mutlu, 04/04/2008
- Re: [cgal-discuss] Mesh Simlification, Andreas Fabri, 04/04/2008
- Re: [cgal-discuss] Mesh Simlification, sinan mutlu, 04/04/2008
- Re: [cgal-discuss] Mesh Simlification, Laurent Rineau, 04/04/2008
- Re: [cgal-discuss] Mesh Simlification, Pierre Alliez, 04/04/2008
- Re: [cgal-discuss] Mesh Simlification, Sylvain Pion, 04/04/2008
- RE: [cgal-discuss] Mesh Simlification, David Lariviere, 04/04/2008
- Re: [cgal-discuss] Mesh Simlification, Laurent Rineau, 04/06/2008
- Re: [cgal-discuss] Mesh Simlification, Fernando Cacciola, 04/04/2008
