- To: "cgal-discuss" <>
- Subject: Re: [cgal-discuss] Help with configuration of CGAL
- Date: Fri, 4 Apr 2008 17:11:09 -0200
Dear,
I am talking about the example in subdiretory you provide. But the problem is not with the example. It is in my invironment.
Thanks very much.
De: | "Andreas Fabri" |
Para: |
Cópia: |
Data: | Fri, 04 Apr 2008 11:39:19 +0200 |
Assunto: | Re: [cgal-discuss] Help with configuration of CGAL |
> Hello,
> I don't know what you mean with "my first example",
> but if it is your own code, with your own vcproj or makefile
> then you better first looked in the examples
> subdirectory and tried to compile examples we provide.
> andreas
> Bernadete wrote:
> > Dear,
> > I am trying to start up with CGAL, but when I was compiling my first
> > example I had the follows errors:
> > Error 17 fatal error LNK1181: cannot open input file
> > 'cgal-vc80-mt-gd.lib' orientation
> > Error 23 fatal error C1083: Cannot open include file:
> > 'CGAL/LEDA/window.h': No such file or directory c:\arquivos de
> > programas\cgal-3.2.1\include\cgal\io\cgal_window.h 30
> > Anybody can orient me with it?
> > Thanks
> > Berna
> > No virus found in this outgoing message.
> > Checked by AVG.
> > Version: 7.5.519 / Virus Database: 269.22.5/1358 - Release Date:
> > 3/4/2008 18:36
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
> E-mail verificado pelo Terra Anti-Spam.
> Para classificar como spam, visite
> http://mail.terra.com.br/cgi-bin/reportspam.cgi?+_d=UyYzNTYwMzUxI3Blcm0hdGVycmEmMSwxMjA3MzAyMDU4LjkyNDM2OC4yNzQ0Mi5jYW1lbmFuYS5oc3QudGVycmEuY29tLmJyLDQ0OTQ=
> Esta mensagem foi verificada pelo E-mail Protegido Terra.
> Scan engine: McAfee VirusScan / Atualizado em 03/04/2008 / Versao: 5.2.00/5266
> Proteja o seu e-mail Terra: http://mail.terra.com.br/
- Re: [cgal-discuss] Help with configuration of CGAL, bmmn, 04/04/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] Help with configuration of CGAL, Mahmood Naderan, 04/05/2008
- RES: [cgal-discuss] Help with configuration of CGAL, Bernadete, 04/05/2008
- RES: [cgal-discuss] Help with configuration of CGAL, Bernadete, 04/07/2008
- Re: [cgal-discuss] Help with configuration of CGAL, Mahmood Naderan, 04/07/2008
- RES: [cgal-discuss] Help with configuration of CGAL, Bernadete, 04/08/2008
