cgal-discuss - Re: [cgal-discuss] Help with configuration of CGAL
  • To:
  • Subject: Re: [cgal-discuss] Help with configuration of CGAL
  • Date: Sun, 6 Apr 2008 22:28:03 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Content-Transfer-Encoding:Message-ID; b=4fUd1HW4NKUhPWmu8Wn03FlSvtxU0au2kdFba9a5NaPKwj66DxZn0sp4efsZo6P/fimTWV0qaN86CBnEskigU2vvM1n/pucbJDhtJ/iRmv1DR34XGe5l+ZdKUfyWwUxjbEpDCHuNZpFhTN0SULd4FgvCQYSz588EBspJJtfXreU=;
>Error \prj0019: A tool returned an error code from "Performing Custom Build
>Step". I got 4 errors like this.
I have had this problem too, but I cannot remember exaclty how did I fix it.
What I remember is that I close the solution and exit VS, then I reopen it
again and click "rebuild solution" in build menu.
Is it the first solution you want to build or you built cgallib.sln prior to
this? What I notice from your post is that you want to build cgalqt_80.sln
seperatly, but as you open cgal_80.sln, the whole solution will open and you
should "build solution" or "rebuild solution" and not "build cgalqt_80".
Hope this help
Mahmood Naderan
http://ce.sharif.edu/~m_naderan
----- Original Message ----
To:
Sent: Monday, April 7, 2008 1:42:54 AM
Subject: RES: [cgal-discuss] Help with configuration of CGAL
Dear,
You are helping me very much. Thank you!!!
See if you can help me with this situation now.
Compiling CGALQT_80 I have a message:
I think if I can fix this, I can start my work with CGAL...
If you can help me with it too, I always thank you.
Bernadete
-----Mensagem original-----
De: Mahmood Naderan
[mailto:]
Enviada em: sábado, 5 de abril de 2008 06:26
Para:
Assunto: Re: [cgal-discuss] Help with configuration of CGAL
>Now the error is with <CGAL/compiler_config.h>. It is not finding
>compiler_config.h and it is not in diretory of CGAL.
it is in "$(CGALROOT)\include\CGAL\config\msvc\CGAL". Add this path to
"tools->option->projects->VC++ directories->include files".
Mahmood Naderan
To:
Sent: Saturday, April 5, 2008 12:39:11 PM
Very good!!!
This worked very well. Thanks a lot!
Berna
De: Mahmood Naderan
[mailto:]
Enviada em: sábado, 5 de abril de 2008 04:08
Para:
>. About the reference to cgal-vc80-mt-gd.lib I didn´t find it to put its
path. But I think I have to compile
> something to get this cgal-vc80-mt-gd.lib. I am a little bit lost
So, if you have not this "lib" file in $(CGALROOT)\lib, build the *.sln file
in "$(CGALROOT)\src. This will create appropriate library files.
Mahmood Naderan
To:
Sent: Saturday, April 5, 2008 3:24:57 AM
Dear Antonino,
My compiler is Visual Studio 2005 Expression Edition. CGAL is 3.3.1. About
LEDA I will change for glut (OpenGL), but first I need to solve this errors
about CGAL. I am looking if I didn´t miss some configuration. Yes I added
library and includes path. About the reference to cgal-vc80-mt-gd.lib I
didn´t find it to put its path. But I think I have to compile something to
get this cgal-vc80-mt-gd.lib. I am a little bit lost.
Thanks a lot
Berna
De: Antonino Mistretta
[mailto:]
Enviada em: sexta-feira, 4 de abril de 2008 06:32
Para:
Hi,
I'm a new user of CGAL library, and I have compiled example and new my
codes.
Can you tell me what IDE and/or compilator use to compile your application?
I think that you have a compiler option error.
Do you have added reference to library 'cgal-vc80-mt-gd.lib'?
Do you have added library path?
Do you have install LEDA package?
2008/4/4, Bernadete
Dear,
I am trying to start up with CGAL, but when I was compiling my first example
I had the follows errors:
Error 17 fatal error LNK1181: cannot open input file 'cgal-vc80-mt-gd.lib'
orientation
Error 23 fatal error C1083: Cannot open include file: 'CGAL/LEDA/window.h':
No such file or directory c:\arquivos de
programas\cgal-3.2.1\include\cgal\io\cgal_window.h 30
Anybody can orient me with it?
Thanks
Berna
No virus found in this outgoing message.
Checked by AVG.
Version: 7.5.519 / Virus Database: 269.22.5/1358 - Release Date: 3/4/2008
18:36
AM
E-mail verificado pelo Terra Anti-Spam.
Para classificar como spam, clique aqui.
Esta mensagem foi verificada pelo E-mail Protegido Terra.
Scan engine: McAfee VirusScan / Atualizado em 03/04/2008 / Versão:
5.2.00/5266
Proteja o seu e-mail Terra: http://mail.terra.com.br/
No virus found in this incoming message.
Checked by AVG.
Version: 7.5.519 / Virus Database: 269.22.6/1360 - Release Date: 4/4/2008
18:02
Checked by AVG.
18:02
____________________________________________________________________________
________
You rock. That's why Blockbuster's offering you one month of Blockbuster
Total Access, No Cost.
http://tc.deals.yahoo.com/tc/blockbuster/text5.com
Para classificar como spam, visite
http://mail.terra.com.br/cgi-bin/reportspam.cgi?+_d=UyYzNTYwMzUxI3Blcm0hdGVy
cmEmMSwxMjA3Mzc5Mzg3LjE2NDgwMi4zMTA5Ny5mb21ib25pLmhzdC50ZXJyYS5jb20uYnIsNjY0
MQ==
Scan engine: McAfee VirusScan / Atualizado em 04/04/2008 / Versão:
5.2.00/5267
________
cmEmMSwxMjA3Mzg3NTc2LjkzOTE1Mi4yOTgxMy5jYWRhcmdhLmhzdC50ZXJyYS5jb20uYnIsODYy
Ng==
5.2.00/5267
____________________________________________________________________________________
