- To:
- Subject: Re: [cgal-discuss] Help with configuration of CGAL
- Date: Sat, 5 Apr 2008 00:07:56 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Content-Transfer-Encoding:Message-ID; b=vSd8KAzSsEJVf1b8n5srIVwAu1UBe6YvEcamMIw0GWvsto6EVa0Vz9eih/9Ixbm8w5DxTMnjCS1uHg81KNDEjIw2jUbp1kDoqXqQgFsj1uWvNNUSfATqGrp0sqzK/St7av31xYcBJ606dwks4xaF/uagHVWNAdBHw02vRVCi8/s=;
>. About the reference to cgal-vc80-mt-gd.lib I didn´t find it to put its
>path. But I think I have to compile
> something to get this cgal-vc80-mt-gd.lib. I am a little bit lost
So, if you have not this "lib" file in $(CGALROOT)\lib, build the *.sln file
in "$(CGALROOT)\src. This will create appropriate library files.
Mahmood Naderan
http://ce.sharif.edu/~m_naderan
----- Original Message ----
To:
Sent: Saturday, April 5, 2008 3:24:57 AM
Subject: RES: [cgal-discuss] Help with configuration of CGAL
Dear Antonino,
My compiler is Visual Studio 2005 Expression Edition. CGAL is 3.3.1. About
LEDA I will change for glut (OpenGL), but first I need to solve this errors
about CGAL. I am looking if I didn´t miss some configuration. Yes I added
library and includes path. About the reference to cgal-vc80-mt-gd.lib I
didn´t find it to put its path. But I think I have to compile something to
get this cgal-vc80-mt-gd.lib. I am a little bit lost.
Thanks a lot
Berna
De: Antonino Mistretta
[mailto:]
Enviada em: sexta-feira, 4 de abril de 2008 06:32
Para:
Assunto: Re: [cgal-discuss] Help with configuration of CGAL
Hi,
I'm a new user of CGAL library, and I have compiled example and new my codes.
Can you tell me what IDE and/or compilator use to compile your application?
I think that you have a compiler option error.
Do you have added reference to library 'cgal-vc80-mt-gd.lib'?
Do you have added library path?
Do you have install LEDA package?
2008/4/4, Bernadete
Dear,
I am trying to start up with CGAL, but when I was compiling my first example
I had the follows errors:
Error 17 fatal error LNK1181: cannot open input file 'cgal-vc80-mt-gd.lib'
orientation
Error 23 fatal error C1083: Cannot open include file: 'CGAL/LEDA/window.h':
No such file or directory c:\arquivos de
programas\cgal-3.2.1\include\cgal\io\cgal_window.h 30
Anybody can orient me with it?
Thanks
Berna
No virus found in this outgoing message.
Checked by AVG.
Version: 7.5.519 / Virus Database: 269.22.5/1358 - Release Date: 3/4/2008
18:36
AM
E-mail verificado pelo Terra Anti-Spam.
Para classificar como spam, clique aqui.
Esta mensagem foi verificada pelo E-mail Protegido Terra.
Scan engine: McAfee VirusScan / Atualizado em 03/04/2008 / Versão:
5.2.00/5266
Proteja o seu e-mail Terra: http://mail.terra.com.br/
No virus found in this incoming message.
Checked by AVG.
Version: 7.5.519 / Virus Database: 269.22.6/1360 - Release Date: 4/4/2008
18:02
Checked by AVG.
18:02
____________________________________________________________________________________
You rock. That's why Blockbuster's offering you one month of Blockbuster
Total Access, No Cost.
http://tc.deals.yahoo.com/tc/blockbuster/text5.com
- Re: [cgal-discuss] Help with configuration of CGAL, bmmn, 04/04/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] Help with configuration of CGAL, Mahmood Naderan, 04/05/2008
- RES: [cgal-discuss] Help with configuration of CGAL, Bernadete, 04/05/2008
- RES: [cgal-discuss] Help with configuration of CGAL, Bernadete, 04/07/2008
- Re: [cgal-discuss] Help with configuration of CGAL, Mahmood Naderan, 04/07/2008
- RES: [cgal-discuss] Help with configuration of CGAL, Bernadete, 04/08/2008
