- To:
- Subject: Re: [cgal-discuss] plane/concave polyhedron intersection
- Date: Fri, 11 Apr 2008 15:18:40 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=Ic1Lr1wAg8a/hIUgiYVoCmNtZa6/mwI8PE76jB9bNGMDIJpDb50+DJLPVMNhVeGE8LqPx10Y1jrdc7pWuK+ooFG5yvqQ7mxp/jLr7qDbbb/agWI+/JINcijaIf0xRpyWP6EwhuMQ1pQ2M5ijYQkO5PtNt65eMFd89CG4OccXDIk=
Hi Peter
thanks for for your quck reply.
> with 3D Nef polyhedra it is not a problem to do intersection of planes
> and polyhedra. The problem in your case is the file format. We don't
> support stl files at the moment.
this is not a problem as writing a parser for stl is really a simple
task... I have a simple library based on FLEX... could it helps ?
> I can write a constructor for stl files
> for you in an hour, but it will not be very efficient. It will construct
> every facet as a separate Nef polyhedron
really ? sound great!
I'm just looking at NEF polyhedron as they are totally new for me.
> So now the question is, how
> big your input data is, and how important the construction efficiency is
> for you.
actually efficenty is not a problem as I'm still experimenting with
STL... and I don't know exactly where I'm gone :-)
> Peter
again, thanks a lot for your help, Peter...
Andy
- plane/concave polyhedron intersection, Andy Hirsh, 04/11/2008
- Re: [cgal-discuss] plane/concave polyhedron intersection, Peter Hachenberger, 04/11/2008
- Re: [cgal-discuss] plane/concave polyhedron intersection, Giampaolo Bellini, 04/11/2008
- Re: [cgal-discuss] plane/concave polyhedron intersection, Andy Hirsh, 04/11/2008
- Re: [cgal-discuss] plane/concave polyhedron intersection, Andy Hirsh, 04/14/2008
- Re: [cgal-discuss] plane/concave polyhedron intersection, Peter Hachenberger, 04/14/2008
