- To:
- Subject: Re: [cgal-discuss] plane/concave polyhedron intersection
- Date: Fri, 11 Apr 2008 19:04:54 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=RZhqITew1uzEIr25opyZwldjAPhT3b/PJ3FZytLkjXEleWSvR/iJAIPq0JhZGUajiPdVhkJEP0XoNf+D5etC4Zj/TupKvz/rStMV+qSFQzWeOGy8xJWxX6YdK26a2EH469/eKI6KHAXcDDYLwnMM5uQrIzzN+ktfCOr4SPb5Dzo=
Hi Peter
I sent last mail while logged on my colleague gmail's account... sorry!
Looking for the rabbit object you talk about in your mail, I found
that there is another simple 3d format named PLY
http://en.wikipedia.org/wiki/PLY_(file_format)... is this better for
the intersection purpose ?
best regards
Andy
On 4/11/08, Giampaolo Bellini
wrote:
> Hi Peter
> thanks for for your quck reply.
> > with 3D Nef polyhedra it is not a problem to do intersection of planes
> > and polyhedra. The problem in your case is the file format. We don't
> > support stl files at the moment.
> this is not a problem as writing a parser for stl is really a simple
> task... I have a simple library based on FLEX... could it helps ?
> > I can write a constructor for stl files
> > for you in an hour, but it will not be very efficient. It will construct
> > every facet as a separate Nef polyhedron
> really ? sound great!
> I'm just looking at NEF polyhedron as they are totally new for me.
> > So now the question is, how
> > big your input data is, and how important the construction efficiency is
> > for you.
> actually efficenty is not a problem as I'm still experimenting with
> STL... and I don't know exactly where I'm gone :-)
> > Peter
> again, thanks a lot for your help, Peter...
> Andy
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- plane/concave polyhedron intersection, Andy Hirsh, 04/11/2008
- Re: [cgal-discuss] plane/concave polyhedron intersection, Peter Hachenberger, 04/11/2008
- Re: [cgal-discuss] plane/concave polyhedron intersection, Giampaolo Bellini, 04/11/2008
- Re: [cgal-discuss] plane/concave polyhedron intersection, Andy Hirsh, 04/11/2008
- Re: [cgal-discuss] plane/concave polyhedron intersection, Andy Hirsh, 04/14/2008
- Re: [cgal-discuss] plane/concave polyhedron intersection, Peter Hachenberger, 04/14/2008
