cgal-discuss - Re: [cgal-discuss] plane/concave polyhedron intersection
  • To:
  • Subject: Re: [cgal-discuss] plane/concave polyhedron intersection
  • Date: Mon, 14 Apr 2008 14:17:04 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=FHfOH1dHfZcDL85X3RCKlRImcCJSg936F3RrGIDvAggAzHeDeUOkd5rjf1XZhLegMf8ijA3UbsSsNb2JBnKvv+6iQZ5Lwjgtmxz4xit37IAKCmi6kvfBD9M0Pq2Kw/vdhoFvd/hmWUMmllR595EgXNr75pGKXBY6K/iXlxa7x7k=
Dear Peter
I have bought a book in order to understand NEF polyhedron basics :-)
As you suggests, I think I'll start with the PLY format instead of the
STL: there is a library at
http://www.tecgraf.puc-rio.br/~diego/professional/rply/
If you can provide me an example for a simple (code made, with few
facets) polyhedron it'll be very usefull.
thanks a lot
Andy
On 4/11/08, Peter Hachenberger
wrote:
> Hi Andy,
> the ply format is better since it is based on the indexed face set idea.
> That means that you first store the coordinates of all vertices and then
> give the facets as list of references to the vertices. Many file formats
> use that---amongst others the off file format, which we use as input. It
> is easy to write a converter ply to off (maybe also easy to find on
> internet), which would allow you to use our normal interface.
