cgal-discuss - Re: [cgal-discuss] Surface Meshing
  • To:
  • Subject: Re: [cgal-discuss] Surface Meshing
  • Date: Mon, 14 Apr 2008 11:49:33 +0200
  • Organization: Inria, Sophia Antipolis, FRANCE
On Sunday 13 April 2008 16:21:50 Philipp Jenke wrote:
> Hi Pierre,
> Polygon soup is ok, but perfect would be a vertex list and three
> indices for each triangle (shared vertex for all adjacent triangles).
> Thanks,
> Philipp
Hi Philipp,
The result of the CGAL surface mesh generator is a data structure embedded in
a 3D triangulation, named the "2D Complex in 3D Triangulation", and
represented by the class
CGAL::Surface_mesh_complex_2_in_triangulation_3<Triangulation>. The
documentation is available at that place:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Surface_mesher_ref/Class_Surface_mesh_complex_2_in_triangulation_3.html
Actually that reference page only says that the class is model of a concept,
so the actual list of types and methods available in that class is here:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Surface_mesher_ref/Concept_SurfaceMeshComplex_2InTriangulation_3.html
What you need is the section "Traversal of the complex", and particularly the
Facet_iterator.
To use that class, you also need to know a little about CGAL triangulations
(types and methods to deal with vertices, cells and facets).
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_3.html
I have attached a modified version of the example
examples/Surface_mesher/mesh_an_implicit_function.cpp you quoted in an other
thread. After the computation, the code outputs the vertices and facets
lists. A second attached modified version outputs the surface mesh in an OFF
file.
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
#include <CGAL/Surface_mesh_default_triangulation_3.h>
#include <CGAL/Complex_2_in_triangulation_3.h>
#include <CGAL/make_surface_mesh.h>
#include <CGAL/Implicit_surface_3.h>
#include <fstream>
// default triangulation for Surface_mesher
typedef CGAL::Surface_mesh_default_triangulation_3 Tr;
// c2t3
typedef CGAL::Complex_2_in_triangulation_3<Tr> C2t3;
typedef Tr::Geom_traits GT;
typedef Tr::Vertex_handle Vertex_handle;
typedef GT::Sphere_3 Sphere_3;
typedef GT::Point_3 Point_3;
typedef GT::FT FT;
typedef FT (*Function)(Point_3);
typedef CGAL::Implicit_surface_3<GT, Function> Surface_3;
FT sphere_function (Point_3 p) {
const FT x2=p.x()*p.x(), y2=p.y()*p.y(), z2=p.z()*p.z();
return x2+y2+z2-1;
int main() {
Tr tr; // 3D-Delaunay triangulation
C2t3 c2t3 (tr); // 2D-complex in 3D-Delaunay triangulation
// defining the surface
Surface_3 surface(sphere_function, // pointer to function
Sphere_3(CGAL::ORIGIN, 2.)); // bounding sphere
// defining meshing criteria
CGAL::Surface_mesh_default_criteria_3<Tr> criteria(30., // angular bound
0.1, // radius bound
0.1); // distance bound
// meshing surface
CGAL::make_surface_mesh(c2t3, surface, criteria, CGAL::Non_manifold_tag());
std::ofstream out_file("output.off");
out_file.imbue(std::locale("POSIX")); // use a POSIX locale
out_file << "OFF\n"
<< tr.number_of_vertices() << " "
<< c2t3.number_of_facets() << " 0\n";
std::map<Vertex_handle, int> vertices_map;
int vertices_counter = 0;
// traversal of the vertices list
for(Tr::Finite_vertices_iterator
vit = tr.finite_vertices_begin(),
end = tr.finite_vertices_end();
vit != end; ++vit)
// note: a vertex iterator is implicitly convertable to a vertex handle
vertices_map[vit] = vertices_counter;
out_file << vit->point() << "\n";
++vertices_counter;
// traversal of the 2D complex
for(C2t3::Facet_iterator
fit = c2t3.facets_begin(),
end = c2t3.facets_end();
fit != end; ++fit)
// a facet is a pair (cell_handle, index)
const Tr::Cell_handle& cell = fit->first;
const int index = fit->second;
const Vertex_handle va = cell->vertex((index+1)&3);
const Vertex_handle vb = cell->vertex((index+2)&3);
const Vertex_handle vc = cell->vertex((index+3)&3);
out_file << "3 "
<< vertices_map[va] << " "
<< vertices_map[vb] << " "
<< vertices_map[vc] << "\n";
// c2t3
typedef GT::FT FT;
return x2+y2+z2-1;
int main() {
// meshing surface
std::cout << "Vertices list... ("
<< tr.number_of_vertices() << " vertices)\n";
vit != end; ++vit)
std::cout << "vertex #" << vertices_counter << " = ("
<< vit->point() << ")\n";
++vertices_counter;
std::cout << "Facets list... ("
<< c2t3.number_of_facets() << " facets)\n";
fit != end; ++fit)
std::cout << "facet "
