Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject)
- To:
- Subject: Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject)
- Date: Mon, 05 May 2008 19:20:52 +0200
Hello Hui Ding,
I have some data files that contain the values 3D points of theI hope you are talking about chapter 27.
object 3D, and I'd like to use CGAL to represent the object. I just
looked into the chapter22 of manuel, and i have some questions about
both concept of science and use of library, I will appreciate it, if
someone gives some helps:
1) I can see that a vertex has /0/-face, the edge has 1 face, and aThe numbers actually indicate the dimension.
facet has 2 faces, but I don't understand how a cell has 3 face? why
not 4, if a cell is a 3 simplex(tetrahedron)?
Thus a cell IS a 3-face, whereas a facet IS a 2-face, an edge a 1-face and a vertex a 0-face.
2) From some basic exemple of chapiter 22, i saw that we get thebtw. it would be helpful to be a little more precise. I assume you are talking about example 27.6.1, right? I'm not sure having understood your question in the right way. In this example the triangulation is written to a file via a std::ofstream using the output operator << .
triangulation information by using "/ostream/", but I dont
understand what every value stands for. (the dimention, number of
finite, non-combinatorial, the number of cells are clear, but the
others i cant figure out, anyone can help?).
This is described under section "I/O" in http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_3.html
3) Could I easily put my 3D points data to Triangulation_3, and thenSee the link above, it is suggested to use GeomView.
use the ostream to output the triangulation information of this
object? and is there any "Viewer" can read this information and show
the object in 3D? Or do i need to write it myself what chapiter do i
need to read?
4) Once I construct the triangulation of my object 3D, I need theI'm currently not aware of any such function.
normal of every facet of every cell, is there already some functions
who do that? or i need to calculate myself? how?
5) I read only chapter 22 for my work right now(cause someone toldYou can have a look into the first introductory chapters about kernels and number types... apart from that chapter 27 (and maybe 28) should be fine.
me so), but if anyone has some conseils to learn the 3D
triangulations like some chapiters or some tuturials
corresponding to 3D triangulation or something else, please tell me?
Best
Manuel
- RE: Welcome to list cgal-discuss, Hui Ding, 05/05/2008
- Triangulation 3D (I'm SORRY that I forgot to change the subject), Hui Ding, 05/05/2008
- Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject), Manuel Caroli, 05/05/2008
- Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject), Monique . Teillaud, 05/06/2008
- Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject), Hui DING, 05/06/2008
- Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject), Thomas Zangl, 05/06/2008
- Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject), Manuel Caroli, 05/06/2008
