Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject)
- To: <>
- Subject: Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject)
- Date: Tue, 6 May 2008 11:33:45 +0200
Thank you for your answer, Monique Teillaud! I will look at it.
Thank you for your answer, Manuel Caroli! And you were right, I was talking about chapiter 27, I dont know why I kept saying 22, maybe cause that's my lucky number, lol.
And
- The output file shows like this (I understand the first 9 lines, but for the others, I dont know..):2) From some basic exemple of chapiter 22, i saw that we get thebtw. it would be helpful to be a little more precise. I assume you are talking about example 27.6.1, right? I'm not sure having understood your question in the right way. In this example the triangulation is written to a file via a std::ofstream using the output operator << .
triangulation information by using "/ostream/", but I dont
understand what every value stands for. (the dimention, number of
finite, non-combinatorial, the number of cells are clear, but the
others i cant figure out, anyone can help?).
This is described under section "I/O" in http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_3.html
3 - the dimension
6 - the number of finite vertices
0 1 0 - the non-combinatorial information about vertices (point, etc)
0 0 0
1 0 0
0 0 1
2 2 2
1 1 1
11 - the number of cells
5 1 3 6 - ?
1 2 3 4 - ?
2 0 3 4 - ?
2 1 0 4 - ?
1 3 2 0 - ?
0 1 3 5 - ?
6 1 3 4 - ?
0 5 3 4 - ?
0 1 5 4 - ?
5 1 6 4 - ?
5 6 3 4 - ?
6 10 9 5 - ?
2 6 3 4 - ?
7 1 3 4 - ?
8 2 1 4 - ?
2 3 5 1 - ?
0 7 8 4 - ?
1 10 9 0 - ?
10 2 8 5 - ?
9 7 3 5 - ?
6 10 8 0 - ?
6 7 9 0 - ?
3) Could I easily put my 3D points data to Triangulation_3, and thenSee the link above, it is suggested to use GeomView.
use the ostream to output the triangulation information of this
object? and is there any "Viewer" can read this information and show
the object in 3D? Or do i need to write it myself what chapiter do i
need to read?
- I jumped over this GeomView part, when I read the manuel. thank you for reminding me. But is it possible I use the GeomView on Windows XP?
thanks again!
Hui
----- Original Message ----- From: <>
To:
Sent: Tuesday, May 06, 2008 10:08 AM
Manuel Caroli wrote:
Hello Hui Ding,
4) Once I construct the triangulation of my object 3D, I need the
normal of every facet of every cell, is there already some functions
who do that? or i need to calculate myself? how?
I'm currently not aware of any such function.
Hi
you can get the points corresponding to the vertices of facet (see manual of Triangulation_3 for the orientation of the facet) then use CGAL::orthogonal_vector (see Kernel manual)
best
Monique Teillaud
----- Original Message ----- From: "Manuel Caroli" <>
To:
Sent: Monday, May 05, 2008 7:20 PM
Hello Hui Ding,
I have some data files that contain the values 3D points of theI hope you are talking about chapter 27.
object 3D, and I'd like to use CGAL to represent the object. I just
looked into the chapter22 of manuel, and i have some questions about
both concept of science and use of library, I will appreciate it, if
someone gives some helps:
1) I can see that a vertex has /0/-face, the edge has 1 face, and aThe numbers actually indicate the dimension.
facet has 2 faces, but I don't understand how a cell has 3 face? why
not 4, if a cell is a 3 simplex(tetrahedron)?
Thus a cell IS a 3-face, whereas a facet IS a 2-face, an edge a 1-face and a vertex a 0-face.
need to read?
4) Once I construct the triangulation of my object 3D, I need theI'm currently not aware of any such function.
5) I read only chapter 22 for my work right now(cause someone toldYou can have a look into the first introductory chapters about kernels and number types... apart from that chapter 27 (and maybe 28) should be fine.
me so), but if anyone has some conseils to learn the 3D
triangulations like some chapiters or some tuturials
corresponding to 3D triangulation or something else, please tell me?
Best
Manuel
- RE: Welcome to list cgal-discuss, Hui Ding, 05/05/2008
- Triangulation 3D (I'm SORRY that I forgot to change the subject), Hui Ding, 05/05/2008
- Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject), Manuel Caroli, 05/05/2008
- Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject), Monique . Teillaud, 05/06/2008
- Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject), Hui DING, 05/06/2008
- Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject), Thomas Zangl, 05/06/2008
- Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject), Manuel Caroli, 05/06/2008
