Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject)
- To: <>
- Subject: Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject)
- Date: Tue, 6 May 2008 16:51:55 +0200
Another question, please, can the Point be negative? because my data are mixed with negatives and positives. values.
----- Original Message ----- From: "Hui DING" <>
To:
Sent: Tuesday, May 06, 2008 4:35 PM
Thanks a lot!
And the GeomView works now on my windowsXP with help of Cygwin, but can I use the CGAL interface to GeomView on platform VC++? if no, how can I view the 3D object with the triangulation information?
----- Original Message ----- From: "Manuel Caroli" <>
To:
Sent: Tuesday, May 06, 2008 3:22 PM
Hui DING wrote:
There is some randomization involved in order to accelerate the algorithm.If you are computing a Delaunay or regular Triangulation of a non-degenerate point set, then this is uniquely defined. Therefore the resulting triangulation is always the same. Even if the point set is degenerate CGAL gives you always the same triangulation.- In the example 27.6.1, it uses the Triangulation_3, I never change the order of insertion, why it changes too? (sometime the number of cells is 12, sometime is 11)?
If you are not computing a Delaunay or regualar triangulation then it depends on the order in which you insert the points.
Note that the indices as written above can change of course.
Be aware that a triangulation of 5 points in IR^3 can consist of either 2 or 3 tetrahedra.
I cite from the manual:
template < class InputIterator >
int t.insert ( InputIterator first, InputIterator last)
Inserts the points in the range [.first, last.). Returns the number of inserted points. Note that this function is not garanteed to insert the points following the order of InputIterator.
Precondition: The value_type of first and last is Point.
best
Manuel
- Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject), (continued)
- Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject), Monique . Teillaud, 05/06/2008
- Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject), Hui DING, 05/06/2008
- Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject), Thomas Zangl, 05/06/2008
- Re: [cgal-discuss] Triangulation 3D (I'm SORRY that I forgot to change the subject), Manuel Caroli, 05/06/2008
