cgal-discuss - Re: [cgal-discuss] Normal generation out of 3d alpha shapes
  • To:
  • Subject: Re: [cgal-discuss] Normal generation out of 3d alpha shapes
  • Date: Sun, 18 May 2008 16:53:42 +0200
Andreas Fabri wrote:
Jonas Schild wrote:
Hi all,
I have the following problem:
I'm constructing a 3d alpha shape from a set of points using CGAL. After creation of the alpha shape, I'm iterating over all facets to extract the triangles. But:
The orientation of the normal (either by using cross product or using CGAL's ortho_vector(point, point, point) of which results are the same) is partially wrong. I've read that the orientation of the triangle is based on orientation of the cell (i.e. pointing into the cell). However, I'm not able to retrieve the normals pointing outside the alpha shape. Part of the problem is, that for certain alpha values, the constructed shape is no solid object. Is it possible to iterate only over alphas where the shape is solid, not necessarily convex?
Furthermore, I don't understand how ccw(int) on the triangulation structure is supposed to work regarding finding the correct orientation thus the normals are pointing outside the volume.
Hi Jonas,
Here comes a partial answer.
With ccw(int) you refer probably to the base class of all 3D traingulations:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/TriangulationDS_3_ref/Class_Triangulation_utils_3.html#Cross_link_anchor_994
As the manual says ccw(int) only makes sense when it is 2D.
What you should use is the undocumented funcyion:
static int Triangulation_utils_3<..>::vertex_triple_index(const int i, const int j)
// indexes of the jth vertex of the facet of a cell
// opposite to vertx i
CGAL_triangulation_precondition( ( i >= 0 && i < 4 ) &&
( j >= 0 && j < 3 ) );
return tab_vertex_triple_index[i][j];
The fact that it is undocumented is a bug.
really? I would say it is more like a matter of taste...
Monique
