- To:
- Subject: Re: [cgal-discuss] Normal generation out of 3d alpha shapes
- Date: Tue, 20 May 2008 12:27:54 -0400 (EDT)
- Importance: Normal
Attached with this email is the complete code.
I have modified the code and removed unnecessary stuff.
I have not attempted to compile it after the modification. But, you can
use the code as a blueprint to get the correct normals.
Hope that works.
> Santosh Tiwari wrote:
>> This is how I got the correct normals for all the boundary facets.
> Hi Santosh,
> I tried using your code, but failed with correctly setting up the Facet
> and Vertex data types, so I was not able to create the lists correctly.
> I then only used your normals to my vertices but they don't seem to be
> correct. My vertices seem to be in a different order. Could you help me
> out with your typedefs?
> Thanks for kindly providing your code!
> Jonas
>> The relevant code.
>> Alpha_shape_3 *as;
>> list<Facet> facets;
>> list<Vertex> vertices;
>> ostringstream facetStream;
>> as->get_alpha_shape_facets(back_inserter(facets),
>> Alpha_shape_3::REGULAR);
>> as->get_alpha_shape_vertices(back_inserter(vertices),
>> cout<<"\n Number of boundary facets = "<<facets.size();
>> cout<<"\n Number of vertices = "<<vertices.size();
>> facetStream<<vertices.size()<<endl;
>> facetStream<<facets.size()<<endl;
>> facetStream<<*as;
>> //You can now read the facetStream. Here is some code to read it.
>> string facetString(facetstream.str());
>> istringstream in;
>> in.str(facetString);
>> in>>numVertices;
>> in>>numFacets;
>> vertices = new double*[numVertices];
>> for (i=0; i<numVertices; i++) {
>> vertices[i] = new double[3];
>> in>>x>>y>>z;
>> vertices[i][0] = x;
>> vertices[i][1] = y;
>> vertices[i][2] = z;
>> facets = new unsigned long int*[numFacets];
>> for (i=0; i<numFacets; i++) {
>> facets[i] = new unsigned long int[3];
>> in>>v1>>v2>>v3;
>> facets[i][0] = v1;
>> facets[i][1] = v2;
>> facets[i][2] = v3;
>> for(i=0; i<numFacets; i++) {
>> x1 = vertices[facets[i][0]][0];
>> y1 = vertices[facets[i][0]][1];
>> z1 = vertices[facets[i][0]][2];
>> x2 = vertices[facets[i][1]][0];
>> y2 = vertices[facets[i][1]][1];
>> z2 = vertices[facets[i][1]][2];
>> x3 = vertices[facets[i][2]][0];
>> y3 = vertices[facets[i][2]][1];
>> z3 = vertices[facets[i][2]][2];
>> //You now have all the facets. You can write them to a STL file.
>> //You can compute the normals for every facet now.
>> //Here is some code to compute the normals.
>> a1 = x3 - x2;
>> a2 = y3 - y2;
>> a3 = z3 - z2;
>> b1 = x2 - x1;
>> b2 = y2 - y1;
>> b3 = z2 - z1;
>> n1 = a2*b3 - a3*b2;
>> n2 = a1*b3 - a3*b1;
>> n3 = a1*b2 - a2*b1;
>> res = sqrt(n1*n1 + n2*n2 + n3*n3);
>> n1 /= res;
>> n2 /= res;
>> n3 /= res;
>> I personally do not prefer accessing the internal data structure of a
>> library even if it permits that. It is very difficult to debug unless
>> you
>> know the data structure really well.
>> __
>> Santosh Tiwari
>> EIB-326 Clemson University
>> http://www.clemson.edu/~stiwari/
>> -----Original Message-----
>> From:
>> [mailto:]
>> Sent: Sunday, May 18, 2008 10:54 AM
>> To:
>> Andreas Fabri wrote:
>>> Jonas Schild wrote:
>>>> Hi all,
>>>> I have the following problem:
>>>> I'm constructing a 3d alpha shape from a set of points using CGAL.
>>>> After creation of the alpha shape, I'm iterating over all facets to
>>>> extract the triangles. But:
>>>> The orientation of the normal (either by using cross product or using
>>>> CGAL's ortho_vector(point, point, point) of which results are the
>>>> same) is partially wrong. I've read that the orientation of the
>>>> triangle is based on orientation of the cell (i.e. pointing into the
>>>> cell). However, I'm not able to retrieve the normals pointing outside
>>>> the alpha shape. Part of the problem is, that for certain alpha
>>>> values, the constructed shape is no solid object. Is it possible to
>>>> iterate only over alphas where the shape is solid, not necessarily
>>>> convex?
>>>> Furthermore, I don't understand how ccw(int) on the triangulation
>>>> structure is supposed to work regarding finding the correct
>>>> orientation thus the normals are pointing outside the volume.
>>> Hi Jonas,
>>> Here comes a partial answer.
>>> With ccw(int) you refer probably to the base class of all 3D
>>> traingulations:
>> http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/TriangulationDS_3_ref/Cl
>> ass_Triangulation_utils_3.html#Cross_link_anchor_994
>>> As the manual says ccw(int) only makes sense when it is 2D.
>>> What you should use is the undocumented funcyion:
>>> static int Triangulation_utils_3<..>::vertex_triple_index(const int i,
>>> const int j)
>>> // indexes of the jth vertex of the facet of a cell
>>> // opposite to vertx i
>>> CGAL_triangulation_precondition( ( i >= 0 && i < 4 ) &&
>>> ( j >= 0 && j < 3 ) );
>>> return tab_vertex_triple_index[i][j];
>>> The fact that it is undocumented is a bug.
>> really? I would say it is more like a matter of taste...
>> Monique
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Santosh Tiwari
Fluor Daniel EIB 326
Clemson University, Clemson, SC 29634
http://www.clemson.edu/~stiwari/#include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
#include <CGAL/Delaunay_triangulation_3.h>
#include <CGAL/Triangulation_hierarchy_3.h>
#include <CGAL/Alpha_shape_3.h>
#include <CGAL/IO/io.h>
#include <iostream>
#include <sstream>
#include <string>
#include <fstream>
#include <list>
using namespace std;
struct K : CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef CGAL::Alpha_shape_vertex_base_3<K>
Vb;
typedef CGAL::Triangulation_hierarchy_vertex_base_3<Vb> Vbh;
typedef CGAL::Alpha_shape_cell_base_3<K>
Fb;
typedef CGAL::Triangulation_data_structure_3<Vbh,Fb> Tds;
typedef CGAL::Delaunay_triangulation_3<K,Tds>
Delaunay;
typedef CGAL::Triangulation_hierarchy_3<Delaunay>
Delaunay_hierarchy;
typedef CGAL::Alpha_shape_3<Delaunay_hierarchy>
Alpha_shape_3;
typedef K::Point_3
Point;
typedef Alpha_shape_3::Alpha_iterator
Alpha_iterator;
typedef Alpha_shape_3::NT
NT;
typedef Alpha_shape_3::Facet
Facet;
typedef Alpha_shape_3::Vertex_handle
Vertex;
void writeData(string& facetString);
int main(int argc, const char* const argv[]) {
if(argc!=2) {
cerr<<"\n Usage: "<<argv[0]<<" point_cloud.dat"<<endl;
exit(1);
int mode;
mode = static_cast<int>(atoi(argv[1]));
// Read the points and compute delaunay triangulation
Delaunay_hierarchy dt;
ifstream is(argv[1]);
if(!is) {
cerr<<"\n Could not open file "<<argv[1]<<" for reading,
exiting \n";
exit(1);
register unsigned long int n;
is>>n;
Point p;
cout<<"\n "<<n<<" points in the file";
for(register unsigned long int i=0; i<n; i++) {
is>>p;
dt.insert(p);
if(i%10000==0) {
cout<<"\n "<<i<<" points read and added to delaunay
triangulation";
cout<<"\n "<<n<<" points read and added to delaunay triangulation";
cout<<"\n Delaunay computed";
// compute alpha shape
Alpha_shape_3 *as = new Alpha_shape_3(dt);
cout<<"\n Alpha shape computed";
// find optimal alpha values
Alpha_shape_3::NT alpha_solid = as->find_alpha_solid();
Alpha_iterator opt = as->find_optimal_alpha(1);
cout<<"\n Smallest alpha value to get a solid through data points is
" <<alpha_solid;
cout<<"\n Optimal alpha value to get one connected component is
"<<*opt;
as->set_alpha(*opt);
assert(as->number_of_solid_components() == 1);
//write the facets
list<Facet> facets;
facetStream<<*as;
writeData(facetStream.str());
cout<<endl;
return 0;
void writeData(string& facetString) {
istringstream in;
double** vertices;
unsigned long int** facets;
register unsigned long int i;
double x, y, z;
unsigned long int v1, v2, v3;
double n1, n2, n3, x1, y1, z1, x2, y2, z2, x3, y3, z3;
double a1, a2, a3, b1, b2, b3, res;
register unsigned long int numVertices;
register unsigned long int numFacets;
in>>numVertices;
in>>numFacets;
in>>x>>y>>z;
vertices[i][0] = x;
vertices[i][1] = y;
vertices[i][2] = z;
//cout<<vertices[i][0]<<", "<<vertices[i][1]<<",
"<<vertices[i][2]<<endl;
in>>v1>>v2>>v3;
facets[i][0] = v1;
facets[i][1] = v2;
facets[i][2] = v3;
a1 = x2 - x1;
a2 = y2 - y1;
a3 = z2 - z1;
b1 = x3 - x2;
b2 = y3 - y2;
b3 = z3 - z2;
n1 = a2*b3 - a3*b2;
n2 = a3*b1 - a1*b3;
n3 = a1*b2 - a2*b1;
n1 = n1/res;
n2 = n2/res;
n3 = n3/res;
//Do whatever you want with facets and normals.
return;
- Normal generation out of 3d alpha shapes, Jonas Schild, 05/16/2008
- Re: [cgal-discuss] Normal generation out of 3d alpha shapes, Andreas Fabri, 05/16/2008
- Re: [cgal-discuss] Normal generation out of 3d alpha shapes, Monique . Teillaud, 05/18/2008
- RE: [cgal-discuss] Normal generation out of 3d alpha shapes, Santosh Tiwari, 05/18/2008
- Re: [cgal-discuss] Normal generation out of 3d alpha shapes, Jonas Schild, 05/20/2008
- Re: [cgal-discuss] Normal generation out of 3d alpha shapes, Santosh Tiwari, 05/20/2008
- Re: [cgal-discuss] Normal generation out of 3d alpha shapes, Jonas Schild, 05/21/2008
- Re: [cgal-discuss] Normal generation out of 3d alpha shapes, Mariette Yvinec, 05/20/2008
