cgal-discuss - Re: [cgal-discuss] Normal generation out of 3d alpha shapes
  • To:
  • Subject: Re: [cgal-discuss] Normal generation out of 3d alpha shapes
  • Date: Tue, 20 May 2008 18:49:16 +0200
Hi Jonas
First I am getting back to your first question.
If you would like to get an alpha_shape that is a solid withb a manifold boundary
you have to use the REGULARIZED version of Alpha_shapes_3
that is the one which is computed by defaut.
If you don't want to use the REGULARIZED version of the Alpha_shapes
you can still select the facets of type REGULAR
that are facets of the alpha_shapes bounding a 3D component
of the Alpha_shapes.
Then to find the outside normals, check if the facet
is described with the incident cell that is inside
the alpha_shapes or with the one that is outside.
(Every facets has two descriptions)
You can for instance run :
if( A.classify(facet.first) == INTERIOR)
facet = A.mirror_facet(facet); // which gives the same facet viewed from the other adjacent cells
Then as Monique told you,
t.triangle(facet.first, facet.second) is oriented
so that .....
Jonas Schild wrote:
Hi all,
I have the following problem:
I'm constructing a 3d alpha shape from a set of points using CGAL. After creation of the alpha shape, I'm iterating over all facets to extract the triangles. But:
The orientation of the normal (either by using cross product or using CGAL's ortho_vector(point, point, point) of which results are the same) is partially wrong. I've read that the orientation of the triangle is based on orientation of the cell (i.e. pointing into the cell). However, I'm not able to retrieve the normals pointing outside the alpha shape. Part of the problem is, that for certain alpha values, the constructed shape is no solid object. Is it possible to iterate only over alphas where the shape is solid, not necessarily convex?
Furthermore, I don't understand how ccw(int) on the triangulation structure is supposed to work regarding finding the correct orientation thus the normals are pointing outside the volume.
Hopefully someone could give me a hint or two ;)
Thanks in advance
Jonas
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
