cgal-discuss - Re: [cgal-discuss] Problem with double in a Convex Hull
  • To:
  • Subject: Re: [cgal-discuss] Problem with double in a Convex Hull
  • Date: Fri, 13 Jun 2008 08:46:29 -0300
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version :content-type:references:x-google-sender-auth; b=JHXroevzOpKriCNwUxfpLMRzsotGXUaXbf3HnozymPEeXY03cFjUihymB4dkyuj0/v mQVEcVK6KnK349yMzbYV60C/hq9QaStDw7oFDJ29qZlep7lr7piRwYykCctiVNspiTl3 uRb98K+rTTAcKtIj9iPrLty2tWOV1WhzloX6I=
"Which kernel are you using? Simple_cartesian<double> or one of the predefined kernels?"
Andreas, the kernel I'm using is the Cartesian<double>
And Mathieu, the "file >> x >> x >> y >> z;" is because the txt where I'm getting the points has the index of the vertex before they coordinate. So, I read the vertex index and subscribe it with the real x coordinate.
Thank you all,
Rafael Roberto
Skype: rafael.roberto
www.rafaelroberto.cjb.net
MSN/Google Talk:
