- To:
- Subject: Re: [cgal-discuss] Problem with double in a Convex Hull
- Date: Fri, 13 Jun 2008 14:05:09 -0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version :content-type:references:x-google-sender-auth; b=sCM06pCmbCNIHfZtrVw6J52/FFAt6IwGEvXZ4VXjUQTAxR1LPXM5BdIR3yiBgJPQfN dAko54EDBI2vgt3xEBhMbOSPwvbO5NpgDQqA86gtOJrX6FFhH2dR3JwAY+1Qf9oSqGAQ Qxh6Q84qSIMFEaO00FeVynvTzQuoajsplhxsQ=
Thank you, Bernd, for your answer.
I understood why I should use this kernel and I changed it in my code. But now, that same code gives me an acess violation in on a CGAL file (xutility). I took a look at samples code on the CGAL Manual and I have no idea what tis could be.
- [cgal-discuss] Problem with double in a Convex Hull, rar3, 06/12/2008
- Re: [cgal-discuss] Problem with double in a Convex Hull, Mathieu Brédif, 06/12/2008
- Re: [cgal-discuss] Problem with double in a Convex Hull, Andreas Meyer, 06/12/2008
- Message not available
- Re: [cgal-discuss] Problem with double in a Convex Hull, Rafael Roberto, 06/13/2008
- Re: [cgal-discuss] Problem with double in a Convex Hull, Bernd Gaertner, 06/13/2008
- [cgal-discuss] CORE, Max, 06/15/2008
