cgal-discuss - Re: [cgal-discuss] Problem with double in a Convex Hull
  • To:
  • Subject: Re: [cgal-discuss] Problem with double in a Convex Hull
  • Date: Fri, 13 Jun 2008 15:33:24 +0200
Rafael Roberto wrote:
Andreas, the kernel I'm using is the Cartesian<double>
Using this kernel, neither exact results not termination of algorithms can be taken for granted, see the corresponding FAQ entry at http://www.cgal.org/FAQ.html#inexact_NT. As indicated on that page, you can replace double by any exact type, or (this is usually better) you can switch to CGAL::Exact_predicates_inexact_constructions_kernel.
Best,
Bernd.
