- To:
- Subject: [cgal-discuss] CGAL build error on Solaris 10 (i386)
- Date: Fri, 13 Jun 2008 18:10:43 +0200
Hello,
I'm trying to build CGAL 3.3.1 on a Solaris 10 i386 system. I have successfully built the same CGAL release on Solaris 10 (sparc) with gcc 4.3.0.
Error I can see in install.log :
/usr/local/gcc-4.2/bin/g++ -O2 -fno-strict-aliasing -frounding-math '-I/opt/routing/src/CGAL-3.3.1/include/CGAL/config/i386_SunOS-5.10_g++-4.2.4' '-I/opt/routing/src/CGAL-3.3.1/include' -I/opt/routing/include/boost-1_35 -DCGAL_USE_F2C -c Geomview_stream.cpp
In file included from /opt/routing/src/CGAL-3.3.1/include/CGAL/IO/Ostream_iterator.h:27,
from /opt/routing/src/CGAL-3.3.1/include/CGAL/IO/Geomview_stream.h:31,
from Geomview_stream.cpp:38:
/opt/routing/src/CGAL-3.3.1/include/CGAL/circulator.h:992: erreur: expected identifier before numeric constant
/opt/routing/src/CGAL-3.3.1/include/CGAL/circulator.h:992: erreur: expected ~@~~X>~@~Y before numeric constant
/opt/routing/src/CGAL-3.3.1/include/CGAL/circulator.h:993: erreur: no default argument for ~@~X<anonymous>~@~Y
/opt/routing/src/CGAL-3.3.1/include/CGAL/circulator.h:997: erreur: ~@~XDD~@~Y
was not declared in this scope
/opt/routing/src/CGAL-3.3.1/include/CGAL/circulator.h:997: erreur: nombre erron�� d'arguments du patron (4 devrait être 3)
/opt/routing/src/CGAL-3.3.1/include/CGAL/circulator.h:993: erreur: provided for ~@~Xtemplate<class I, class TT, int <anonymous> > class CGAL::Circulator_from_iiterator~@~Y
/opt/routing/src/CGAL-3.3.1/include/CGAL/circulator.h:1045: erreur: nombre erroné d'arguments du patron (4 devrait être 3)
On this system, I have installed :
- Sun Studio 12
- GCC 4.2.4
- GCC 4.3.1
With all compilers, I obtain the same error.
My install log is :
log of ./install_cgal --prefix=/opt/routing
called by bertrand on vendredi 13 juin 2008 16 h 32 CEST
CGAL_DIR is /opt/routing/src/CGAL-3.3.1
This is install_cgal version 39460.
Looking for POSIX utilities...
getconf is /bin/getconf.
Path for Posix utilities: /usr/xpg4/bin /usr/ccs/bin /usr/bin /opt/SUNWspro/bin
basename is /usr/xpg4/bin/basename.
dirname is /usr/bin/dirname.
uname is /usr/bin/uname.
cat is /usr/bin/cat.
touch is /usr/bin/touch.
cp is /usr/xpg4/bin/cp.
mv is /usr/xpg4/bin/mv.
rm is /usr/xpg4/bin/rm.
ln is /usr/xpg4/bin/ln.
ls is /usr/xpg4/bin/ls.
chmod is /usr/bin/chmod.
mkdir is /usr/bin/mkdir.
sed is /usr/xpg4/bin/sed.
grep is /usr/xpg4/bin/grep.
tr is /usr/xpg4/bin/tr.
awk is /usr/xpg4/bin/awk.
tee is /usr/bin/tee.
find is /usr/xpg4/bin/find.
tar is /usr/bin/tar.
sed respects newline.
CUSTOM_CXXFLAGS is
Parsing support specfiles for 3rd party libraries:
BOOST
BOOST_PROGRAM_OPTIONS
MS_BOOST_PROGRAM_OPTIONS
BOOST_PROGRAM_OPTIONS_GCC
BOOST_BIMAP
X11
GMP
GMPXX
MPFR
ZLIB
ZLIBMS
APPLEVECLIB
SUNPERFORMANCECC
SUNPERFORMANCEGCC
SGICOMPLIB
MKL64
MKL32
MKLWIN64
MKLWIN32
ACML
ACMLWIN
BLASIFORTATLAS
BLASGCCATLAS
BLASWINATLAS
REFBLASGCC
REFBLASLINUXGCC
REFBLASSHARED
REFBLASWIN
CBLASWIN
LEDA
LEDA5X
LEDAMS
LEDA5XMS
LEDAWIN
LEDAWINMS
OPENGL
OPENGL_W32
DEFAULTLAPACK
DEFAULTLAPACKWIN
REFLAPACKLINUXGCC
REFLAPACKWIN
CLAPACKWIN
QT3MT
QT3ST
QT3MSMT
QT3MSST
TAUCSWINLAPACK
TAUCSWINATLAS
TAUCSLAPACK
TAUCSATLAS
TAUCSFREEBSDLAPACK
TAUCSFREEBSDATLAS
TAUCSDARWIN
TAUCSIRIXCC32
TAUCSIRIXCC64
CGAL version is 3.3.1.
Looking for GNU/make...
gmake is /usr/sfw/bin/gmake.
GNU Make found in standard directories.
expr is /usr/xpg4/bin/expr.
use _expr_expr() for evaluating arithmetic expressions.
OS is i386_SunOS-5.10.
Cached COMPILER...
CC@SUNPRO@/bin/cc@/@
Found compiler SUNPRO 5.90.
Cached COMPILER...
g++@GNU@/usr/local/bin/gcc@/@
Found compiler GNU 4.3.1.
g++ is /usr/local/gcc-4.2/bin/g++.
gcc is /usr/local/gcc-4.2/bin/gcc.
Compiler version test compiled.
Found compiler GNU 4.2.4.
CC is /bin/CC.
cc is /bin/cc.
Cached COMPILER...
i386_SunOS-5.10_CC-5.90 has already been registered.
Choosing SUNPRO 5.90 as compiler.
Cached CGAL_INSTALL_VERSION... 39460
Cached BOOST_INCL_DIR...
Cached BOOST_LIB_DIR...
Cached BOOST_VERSION... 1.35.0
Cached BOOST_PROGRAM_OPTIONS_INCL_DIR...
Cached BOOST_PROGRAM_OPTIONS_LIB_DIR...
Cached BOOST_PROGRAM_OPTIONS_VERSION...
Cached BOOST_BIMAP_INCL_DIR...
Cached BOOST_BIMAP_LIB_DIR...
Cached BOOST_BIMAP_VERSION...
Cached X11_INCL_DIR...
Cached X11_LIB_DIR...
Cached X11_VERSION... 11.0
Cached GMP_INCL_DIR...
Cached GMP_LIB_DIR...
Cached GMP_VERSION...
Cached GMPXX_INCL_DIR...
Cached GMPXX_LIB_DIR...
Cached GMPXX_VERSION...
Cached MPFR_INCL_DIR...
Cached MPFR_LIB_DIR...
Cached MPFR_VERSION...
Cached ZLIB_INCL_DIR...
Cached ZLIB_LIB_DIR...
Cached ZLIB_VERSION... 1.2.3
Cached BLAS_INCL_DIR...
Cached BLAS_LIB_DIR...
Cached BLAS_VERSION... 0
Cached LAPACK_INCL_DIR...
Cached LAPACK_LIB_DIR...
Cached LAPACK_VERSION... 0
Cached ATLAS_INCL_DIR...
Cached ATLAS_LIB_DIR...
Cached ATLAS_VERSION...
Cached LEDA_INCL_DIR...
Cached LEDA_LIB_DIR...
Cached LEDA_VERSION...
Cached LEDAWIN_INCL_DIR...
Cached LEDAWIN_LIB_DIR...
Cached LEDAWIN_VERSION...
Cached OPENGL_INCL_DIR...
Cached OPENGL_LIB_DIR...
Cached OPENGL_VERSION... 2.1
Cached QT_INCL_DIR...
Cached QT_LIB_DIR...
Cached QT_VERSION...
Cached TAUCS_INCL_DIR...
Cached TAUCS_LIB_DIR...
Cached TAUCS_VERSION...
Cached BOOST_SUPPORT... y
Cached BOOST_PROGRAM_OPTIONS_SUPPORT...
Cached MS_BOOST_PROGRAM_OPTIONS_SUPPORT...
Cached BOOST_PROGRAM_OPTIONS_GCC_SUPPORT...
Cached BOOST_BIMAP_SUPPORT...
Cached X11_SUPPORT... y
Cached GMP_SUPPORT...
Cached GMPXX_SUPPORT...
Cached MPFR_SUPPORT...
Cached ZLIB_SUPPORT... y
Cached ZLIBMS_SUPPORT...
Cached APPLEVECLIB_SUPPORT...
Cached SUNPERFORMANCECC_SUPPORT... y
Cached SUNPERFORMANCEGCC_SUPPORT...
Cached SGICOMPLIB_SUPPORT...
Cached MKL64_SUPPORT...
Cached MKL32_SUPPORT...
Cached MKLWIN64_SUPPORT...
Cached MKLWIN32_SUPPORT...
Cached ACML_SUPPORT...
Cached ACMLWIN_SUPPORT...
Cached BLASGCCATLAS_SUPPORT...
Cached BLASWINATLAS_SUPPORT...
Cached REFBLASGCC_SUPPORT...
Cached REFBLASLINUXGCC_SUPPORT...
Cached REFBLASSHARED_SUPPORT...
Cached REFBLASWIN_SUPPORT...
Cached CBLASWIN_SUPPORT...
Cached LEDA_SUPPORT...
Cached LEDA5X_SUPPORT...
Cached LEDAMS_SUPPORT...
Cached LEDA5XMS_SUPPORT...
Cached LEDAWIN_SUPPORT...
Cached LEDAWINMS_SUPPORT...
Cached OPENGL_SUPPORT... y
Cached OPENGL_W32_SUPPORT...
Cached DEFAULTLAPACK_SUPPORT...
Cached DEFAULTLAPACKWIN_SUPPORT...
Cached REFLAPACKLINUXGCC_SUPPORT...
Cached REFLAPACKWIN_SUPPORT...
Cached CLAPACKWIN_SUPPORT...
Cached QT3MT_SUPPORT...
Cached QT3ST_SUPPORT...
Cached QT3MSMT_SUPPORT...
Cached QT3MSST_SUPPORT...
Cached TAUCSWINLAPACK_SUPPORT...
Cached TAUCSWINATLAS_SUPPORT...
Cached TAUCSLAPACK_SUPPORT...
Cached TAUCSATLAS_SUPPORT...
Cached TAUCSFREEBSDLAPACK_SUPPORT...
Cached TAUCSFREEBSDATLAS_SUPPORT...
Cached TAUCSDARWIN_SUPPORT...
Cached TAUCSIRIXCC32_SUPPORT...
Cached TAUCSIRIXCC64_SUPPORT...
Cached CUSTOM_CXXFLAGS... -I/opt/routing/include/boost-1_35
Cached CUSTOM_LDFLAGS... -L/opt/routing/lib
Cached LONG_NAME_PROBLEM...
Cached ENABLE_SHARED... y
Cached ENABLE_STATIC... y
Choosing GNU 4.2.4 as compiler.
WARNING: Directory /opt/routing/src/CGAL-3.3.1/lib/i386_SunOS-5.10_g++-4.2.4 does not exist, it will be created.
WARNING: Directory /opt/routing/src/CGAL-3.3.1/include/CGAL/config/i386_SunOS-5.10_g++-4.2.4 does not exist, it will be created.
WARNING: Directory /opt/routing/src/CGAL-3.3.1/include/CGAL/config/i386_SunOS-5.10_g++-4.2.4/CGAL does not exist, it will be created.
Running configuration tests...
CCTYPE_MACRO_BUG test compiled.
CCTYPE_MACRO_BUG test linking succeeded.
CCTYPE_MACRO_BUG test execution succeeded.
COMMA_BUG test compiled.
COMMA_BUG test linking succeeded.
COMMA_BUG test execution succeeded.
CONVERSION_OPERATOR_BUG test compiled.
CONVERSION_OPERATOR_BUG test linking succeeded.
CONVERSION_OPERATOR_BUG test execution succeeded.
DEDUCABLE_CONTEXT_BUG test compiled.
DEDUCABLE_CONTEXT_BUG test linking succeeded.
DEDUCABLE_CONTEXT_BUG test execution succeeded.
DEEP_DEPENDENT_TEMPLATE_BUG test compiled.
DEEP_DEPENDENT_TEMPLATE_BUG test linking succeeded.
DEEP_DEPENDENT_TEMPLATE_BUG test execution succeeded.
DENORMALS_COMPILE_BUG test compiled.
DENORMALS_COMPILE_BUG test linking succeeded.
DENORMALS_COMPILE_BUG test execution succeeded.
IEEE_754_BUG test compiled.
IEEE_754_BUG test linking succeeded.
IEEE_754_BUG test execution succeeded.
ISTREAM_INT_BUG test compiled.
ISTREAM_INT_BUG test linking succeeded.
ISTREAM_INT_BUG test execution succeeded.
LONGNAME_BUG test compiled.
LONGNAME_BUG test linking succeeded.
LONGNAME_BUG test execution succeeded.
LONG_LONG_IO_BUG test compiled.
LONG_LONG_IO_BUG test linking succeeded.
LONG_LONG_IO_BUG test execution succeeded.
MATCHING_BUG_4 test compiled.
MATCHING_BUG_4 test linking succeeded.
MATCHING_BUG_4 test execution succeeded.
MATCHING_BUG_5 test compiled.
MATCHING_BUG_5 test linking succeeded.
MATCHING_BUG_5 test execution succeeded.
MATCHING_BUG_6 test compiled.
MATCHING_BUG_6 test linking succeeded.
MATCHING_BUG_6 test execution succeeded.
MISSING_TEMPLATE_VECTOR_CONSTRUCTORS_BUG test compiled.
MISSING_TEMPLATE_VECTOR_CONSTRUCTORS_BUG test linking succeeded.
MISSING_TEMPLATE_VECTOR_CONSTRUCTORS_BUG test execution succeeded.
NESTED_CLASS_FRIEND_DECLARATION_BUG test compiled.
NESTED_CLASS_FRIEND_DECLARATION_BUG test linking succeeded.
NESTED_CLASS_FRIEND_DECLARATION_BUG test execution succeeded.
NET2003_MATCHING_BUG test compiled.
NET2003_MATCHING_BUG test linking succeeded.
NET2003_MATCHING_BUG test execution succeeded.
LIMITS test compiled.
LIMITS test linking succeeded.
LIMITS test execution succeeded.
LOCALE test compiled.
LOCALE test linking succeeded.
LOCALE test execution succeeded.
LONG_DOUBLE_IO test compiled.
LONG_DOUBLE_IO test linking succeeded.
LONG_DOUBLE_IO test execution succeeded.
LONG_LONG test compiled.
LONG_LONG test linking succeeded.
LONG_LONG test execution succeeded.
NEXTAFTER test compiled.
NEXTAFTER test linking succeeded.
NEXTAFTER test execution succeeded.
STDC_NAMESPACE test compiled.
STDC_NAMESPACE test linking succeeded.
STDC_NAMESPACE test execution succeeded.
STL test compiled.
STL test linking succeeded.
STL test execution succeeded.
TMPL_IN_TMPL_DEPENDING_FUNCTION_PARAM test compiled.
TMPL_IN_TMPL_DEPENDING_FUNCTION_PARAM test linking succeeded.
TMPL_IN_TMPL_DEPENDING_FUNCTION_PARAM test execution succeeded.
TMPL_IN_TMPL_PARAM test compiled.
TMPL_IN_TMPL_PARAM test linking succeeded.
TMPL_IN_TMPL_PARAM test execution succeeded.
NUMERIC_LIMITS_BUG test compiled.
NUMERIC_LIMITS_BUG test linking succeeded.
NUMERIC_LIMITS_BUG test execution succeeded.
OUTOFLINE_MEMBER_DEFINITION_BUG test compiled.
OUTOFLINE_MEMBER_DEFINITION_BUG test linking succeeded.
OUTOFLINE_MEMBER_DEFINITION_BUG test execution succeeded.
OUTOFLINE_TEMPLATE_MEMBER_DEFINITION_BUG test compiled.
OUTOFLINE_TEMPLATE_MEMBER_DEFINITION_BUG test linking succeeded.
OUTOFLINE_TEMPLATE_MEMBER_DEFINITION_BUG_2 test compiled.
OUTOFLINE_TEMPLATE_MEMBER_DEFINITION_BUG_2 test linking succeeded.
OUTOFLINE_TEMPLATE_MEMBER_DEFINITION_BUG_2 test execution succeeded.
SUNPRO_RWSTD test compiled.
SUNPRO_RWSTD test linking succeeded.
SUNPRO_RWSTD test execution succeeded.
TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG test compiled.
TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG test linking succeeded.
TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG test execution succeeded.
USING_BASE_MEMBER_BUG test compiled.
USING_BASE_MEMBER_BUG test linking succeeded.
USING_BASE_MEMBER_BUG test execution succeeded.
USING_BASE_MEMBER_BUG_2 test compiled.
USING_BASE_MEMBER_BUG_2 test linking succeeded.
USING_BASE_MEMBER_BUG_2 test execution succeeded.
USING_BASE_MEMBER_BUG_3 test compiled.
USING_BASE_MEMBER_BUG_3 test linking succeeded.
USING_BASE_MEMBER_BUG_3 test execution succeeded.
Trying to autofind 3rd party libraries...
Testing support for BOOST ...
OK: requirements and incompatibilities.
Testing with default flags.
BOOST test compiled.
BOOST test linking succeeded.
BOOST test execution succeeded.
OK: BOOST test program.
Regards,
JKB
- [cgal-discuss] CGAL build error on Solaris 10 (i386), BERTRAND Joël, 06/13/2008
- Re: [cgal-discuss] CGAL build error on Solaris 10 (i386), Sylvain Pion, 06/13/2008
- Re: [cgal-discuss] CGAL build error on Solaris 10 (i386), BERTRAND Joël, 06/13/2008
- Re: [cgal-discuss] CGAL build error on Solaris 10 (i386), BERTRAND Joël, 06/14/2008
- Re: [cgal-discuss] CGAL build error on Solaris 10 (i386), Sylvain Pion, 06/14/2008
- Re: [cgal-discuss] CGAL build error on Solaris 10 (i386), BERTRAND Joël, 06/15/2008
