- To:
- Subject: Re: [cgal-discuss] CGAL build error on Solaris 10 (i386)
- Date: Fri, 13 Jun 2008 19:10:48 +0200
- Organization: INRIA
BERTRAND Joël a écrit :
Hello,
I'm trying to build CGAL 3.3.1 on a Solaris 10 i386 system. I have successfully built the same CGAL release on Solaris 10 (sparc) with gcc 4.3.0.
Error I can see in install.log :
/usr/local/gcc-4.2/bin/g++ -O2 -fno-strict-aliasing -frounding-math '-I/opt/routing/src/CGAL-3.3.1/include/CGAL/config/i386_SunOS-5.10_g++-4.2.4' '-I/opt/routing/src/CGAL-3.3.1/include' -I/opt/routing/include/boost-1_35 -DCGAL_USE_F2C -c Geomview_stream.cpp
In file included from /opt/routing/src/CGAL-3.3.1/include/CGAL/IO/Ostream_iterator.h:27,
from /opt/routing/src/CGAL-3.3.1/include/CGAL/IO/Geomview_stream.h:31,
from Geomview_stream.cpp:38:
/opt/routing/src/CGAL-3.3.1/include/CGAL/circulator.h:992: erreur: expected identifier before numeric constant
/opt/routing/src/CGAL-3.3.1/include/CGAL/circulator.h:992: erreur: expected ~@~~X>~@~Y before numeric constant
/opt/routing/src/CGAL-3.3.1/include/CGAL/circulator.h:993: erreur: no default argument for ~@~X<anonymous>~@~Y
/opt/routing/src/CGAL-3.3.1/include/CGAL/circulator.h:997: erreur: ~@~XDD~@~Y
was not declared in this scope
/opt/routing/src/CGAL-3.3.1/include/CGAL/circulator.h:997: erreur: nombre erron�� d'arguments du patron (4 devrait être 3)
/opt/routing/src/CGAL-3.3.1/include/CGAL/circulator.h:993: erreur: provided for ~@~Xtemplate<class I, class TT, int <anonymous> > class CGAL::Circulator_from_iiterator~@~Y
/opt/routing/src/CGAL-3.3.1/include/CGAL/circulator.h:1045: erreur: nombre erroné d'arguments du patron (4 devrait être 3)
On this system, I have installed :
- Sun Studio 12
- GCC 4.2.4
- GCC 4.3.1
With all compilers, I obtain the same error.
Sounds like some header file is defining a macro with the same name
as one of the template arguments used at the line 992 of circulator.h
(SS? DD ?).
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
smime.p7s
Description: S/MIME Cryptographic Signature
- [cgal-discuss] CGAL build error on Solaris 10 (i386), BERTRAND Joël, 06/13/2008
- Re: [cgal-discuss] CGAL build error on Solaris 10 (i386), Sylvain Pion, 06/13/2008
- Re: [cgal-discuss] CGAL build error on Solaris 10 (i386), BERTRAND Joël, 06/13/2008
- Re: [cgal-discuss] CGAL build error on Solaris 10 (i386), BERTRAND Joël, 06/14/2008
- Re: [cgal-discuss] CGAL build error on Solaris 10 (i386), Sylvain Pion, 06/14/2008
- Re: [cgal-discuss] CGAL build error on Solaris 10 (i386), BERTRAND Joël, 06/15/2008
