- To:
- Subject: Re: [cgal-discuss] Difference between Lazy_exact and Filtered_kernel?
- Date: Thu, 03 Jul 2008 14:03:55 +0200
Thomas Zangl - Home wrote:
Am Thu, 03 Jul 2008 10:06:29 +0200, schrieb "Andreas Fabri" <>:
Hi!
The lazy exact kernel stores DAGs (directed acyclic graph) of geometric and
arithmetic operations.
Is that the expresion to compute some predicate?
Each node of the DAG stores
- a geometric object or number with intervals of doubles,
- the type of the geometric or arithmetic operation
- pointers to the DAG nodes representing the operands of the
geometric/arithmetic
operation
When a predicate on a lazy object fails the postponed exact computation
is replayed from the information stored in the DAG.
So, the lazy object is more or less a caching?
It's not a cache, but a tracking of history, for repeating
a sequence of operations for an exact type if one cannot
securely evaluate a predicate with the interval approximations.
Maybe have a look at the following paper:
ftp://ftp-sop.inria.fr/geometrica/pion/publis/lazy-kernel.pdf
E.g. if I query the lazy kernel for the intersection between two
identical segments a few times, only the first intersection test is
made and all subsequent tests are returned from the DAG but only if the
two segments remain unchanged?
The Filtered_kernel only provides exact predicates, that is all constructions
are double constructions.
How can it be then that the Exact_constr._exact_pred. kernel uses a
defintion like this:
typedef Lazy_kernel<Simple_cartesian<Gmpq> >
Exact_predicates_exact_constructions_kernel;
The constructions are done using Gmpq so they are considered exact,
arent they? If thats true, the filtered_kernel does only predicates and
needs an exact number type like Gmpq to produce exact construction,
true?
The constructions are done with Cartesian<Interval_nt>
and the fallback is Simple_cartesian<Gmpq>
If the constructions were always done with Gmpq there would be no performance
gain.
Is my conclusion true:
Filtered_kernel<Simple_cartesian<Lazy_exact_nt<Gmpq > > > : first,
use a cheap (semi-)static filter, then fall back to the lazy kernel
(Interval arithmetic) and finally use exact computations.
Lazy_kernel<Simple_cartesian<Gmpq> > : first try to use the lazy
kernel and then fall back to exact computations.
So to compare their performance doesn't really make sense. The latter is
faster but provides no exact constructions.
Ok. My goal was to show that different kernels (and the way how
filters are chained) influence the runtime. So I can compare a
Simple_cartesian<Gmpq> along with a Lazy_kernel<Simple_cartesian<Gmpq>
and conclude about it effect (I bet it will give a speedup) ? Is this
true?
It should give speedup.
As the Lazy_kernel is a recent feature we observed cases though
where Simple_cartesian<Lazy_exact_nt> was faster than Lazy_kernel<..>
Although one would expect the geometric expression tree of an algorithm
to have less nodes than an arithmetic expression tree this is not
always the case.
andreas
TIA,
- [cgal-discuss] Difference between Lazy_exact and Filtered_kernel?, Thomas Zangl - Home, 07/02/2008
- Re: [cgal-discuss] Difference between Lazy_exact and Filtered_kernel?, Andreas Fabri, 07/03/2008
- Re:[cgal-discuss] Difference between Lazy_exact and Filtered_kernel?, Thomas Zangl - Home, 07/03/2008
