cgal-discuss - Re: [cgal-discuss] Difference between Lazy_exact and Filtered_kernel?
  • To:
  • Subject: Re: [cgal-discuss] Difference between Lazy_exact and Filtered_kernel?
  • Date: Thu, 03 Jul 2008 15:21:43 +0200
Thomas Zangl - Home wrote:
Am Thu, 03 Jul 2008 14:03:55 +0200, schrieb "Andreas Fabri" <>:
Hi!
The lazy exact kernel stores DAGs (directed acyclic graph) of geometric and
arithmetic operations.
And the Filtered_Kernel only uses interval arithmetic for some
pre-defined predicates?
For all predicates
Sorry, but I did not get yet what the *main* difference between the
Lazy_kernel and Filtered_kernel is.
The main difference is that
The lazy kernel is exact_predicates_exact_constructions
The Filtered kernel is only exact_predicates
andreas
As far as I was able to extract from docs, sources and papers is:
Filtered_kernel:
* Interval arithmetic and maybe static-filters (if not disabled)
Lazy_kernel:
* Stores DAGs of arithmetic operations, geometric constructions and predicates. * Uses interval arithmetic (''Approximate'') and reverts back to exact
computations if the IA is unsure
Is that correct? So, is the use of caching DAGs the only difference
between the Lazy_kernel and the Filtered_kernel?
TIA!,
