cgal-discuss - Re: [cgal-discuss] point lying over a line problem
  • To: <>
  • Subject: Re: [cgal-discuss] point lying over a line problem
  • Date: Wed, 23 Jul 2008 14:10:19 -0300
  • Organization: Geometry Factory
Hi Alejandro,
I see your point but as soon as you start using double precision, the
"mathematical sense" is out of question, right? So that a < b is not
true if they are within tolerance.
There is a, say, tolerance-based school of flaoting point programming which works very well in several fields like computer graphics, simulations, numerical analysis, etc, but just doesn't work in geometric computing as it depends on (discrete) combinatorial properties.
You might find further insight reading the following usenet discussion on the subject:
http://tinyurl.com/694x7g
HTH
Fernando Cacciola
www.geometryfactory.com
