cgal-discuss - RE: [cgal-discuss] point lying over a line problem
  • To: <>
  • Subject: RE: [cgal-discuss] point lying over a line problem
  • Date: Thu, 24 Jul 2008 08:58:31 +0100
Alejandro,
It may be off-topic but I would recommend Netbeans (C++) over Eclipse, where
the former has far better support for nearly *all* the need to (easily) go
into the billions of header files -- you'll pleasantly discover..
Regards,
Xiaofan
________________________________
[mailto:]
Sent: Wed 7/23/2008 22:00
To:
Subject: Re: [cgal-discuss] point lying over a line problem
Well, that is subjective because for me 20 is honestly way beyond, so
it doesn't make sense to set the precision of cout to 20 for doubles.
Anyways, do you know by chance in which file I can find the code that
computes the oriented side? I'm using Eclipse and you may know that
the indexer is broken when you work with large projects.
Thanks again for replying,
Alejandro M. Aragón
On Jul 23, 2008, at 3:36 PM, Fernando Cacciola wrote:
> Alejandro Aragon wrote:
>> Oh, and for your information, the precision(20) that you suggested is
>> stupid because you're way beyond the precision for that type
> numeric_limits<double>::digits10 is 15 in a typical implementation,
> so I wouldn't say 20 is way beyond that.
> Also, according to this paper:
> http://www.open-std.org/jtc1/sc22/wg21/docs/papers/2006/n2005.pdf
> 17 would be a reasonable precision for outputing double values in
> decimal format
>> , so you're basically outputting garbage.
> What makes you think that using more decimal digits than minimally
> required results in garbage??
> Try this for yourself:
> double d = ( 1.0 / 3.0 ) + numeric_limits<double>::epsilon() ;
> cout.precision(numeric_limits<double>::digits10); cout << d << endl ;
> cout.precision(20); cout << d << endl ;
> cout.precision(40); cout << d << endl ;
> cout.precision(200); cout << d << endl ;
> Finally: did you understand that your point IS NOT really on the
> line because the actual coordinates are not exactly the same as the
> decimal literals you used to initialized them?
> Best
> Fernando Cacciola
> www.geometryfactory.com
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
<<winmail.dat>>
