cgal-discuss - Re: [cgal-discuss] iterator_distance won't compile
  • To:
  • Subject: Re: [cgal-discuss] iterator_distance won't compile
  • Date: Thu, 25 Sep 2008 22:07:22 +0200
Roger House a écrit :
Sylvain:
Thank you for your reply. I looked at Polygon_2_edge_iterator.h, but I don't see where
"const" might be inserted. Below is an excerpt from that file which would seem to be the place to make changes. If you can make the required changes in a reply, I will see if they fix the iterator_distance problem.
Here is the patched file attached.
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
// Copyright (c) 1997 Utrecht University (The Netherlands),
// ETH Zurich (Switzerland), Freie Universitaet Berlin (Germany),
// INRIA Sophia-Antipolis (France), Martin-Luther-University Halle-Wittenberg
// (Germany), Max-Planck-Institute Saarbruecken (Germany), RISC Linz
(Austria),
// and Tel-Aviv University (Israel). All rights reserved.
// This file is part of CGAL (www.cgal.org); you can redistribute it and/or
// modify it under the terms of the GNU Lesser General Public License as
// published by the Free Software Foundation; version 2.1 of the License.
// See the file LICENSE.LGPL distributed with CGAL.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the
software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL:
svn+ssh://scm.gforge.inria.fr/svn/cgal/trunk/Polygon/include/CGAL/Polygon_2/Polygon_2_edge_iterator.h
// $Id: Polygon_2_edge_iterator.h 45787 2008-09-25 19:15:00Z spion $
// Author(s) : Wieger Wesselink, Geert-Jan Giezeman
#ifndef CGAL_POLYGON_2_EDGE_ITERATOR_H
#define CGAL_POLYGON_2_EDGE_ITERATOR_H
#include <iterator>
#include <CGAL/circulator.h>
CGAL_BEGIN_NAMESPACE
template <class Traits_, class Container_> class Polygon_2;
template <class Segment_>
class Polygon_2__Segment_ptr
public:
typedef Segment_ Segment;
Polygon_2__Segment_ptr(Segment const &seg) :m_seg(seg){}
Segment* operator->() {return &m_seg;}
private:
Segment m_seg;
class Polygon_2_edge_iterator {
public:
typedef typename std::iterator_traits<typename
Container_::iterator>::iterator_category iterator_category;
typedef typename Traits_::Segment_2 Segment_2;
typedef typename Traits_::Segment_2 value_type;
typedef Container_ Container;
typedef typename Container_::const_iterator const_iterator;
typedef typename Container_::difference_type difference_type;
typedef Segment_2* pointer;
typedef Segment_2& reference;
private:
const Container_* container; // needed for dereferencing the last edge
const_iterator first_vertex; // points to the first vertex of the edge
public:
Polygon_2_edge_iterator() {}
Polygon_2_edge_iterator(const Container_* c, const_iterator f)
: container(c), first_vertex(f) {}
bool operator==(
const Polygon_2_edge_iterator<Traits_, Container_>& x) const
return first_vertex == x.first_vertex;
bool operator!=(
return !(first_vertex == x.first_vertex);
Segment_2 operator*() const {
const_iterator second_vertex = first_vertex;
++second_vertex;
if (second_vertex == container->end())
second_vertex = container->begin();
typename Traits_::Construct_segment_2 construct_segment_2 =
Traits_().construct_segment_2_object();
return construct_segment_2(*first_vertex, *second_vertex);
Polygon_2__Segment_ptr<Segment_2> operator->() const
{return Polygon_2__Segment_ptr<Segment_2>(operator*());}
Polygon_2_edge_iterator<Traits_, Container_>& operator++() {
++first_vertex;
return *this;
Polygon_2_edge_iterator<Traits_, Container_> operator++(int) {
Polygon_2_edge_iterator<Traits_, Container_> tmp = *this;
++*this;
return tmp;
Polygon_2_edge_iterator<Traits_, Container_>& operator--() {
--first_vertex;
return *this;
Polygon_2_edge_iterator<Traits_, Container_> operator--(int) {
--*this;
return tmp;
// random access iterator requirements
operator+=(difference_type n) {
first_vertex += n;
return *this;
operator+(difference_type n) const {
return Polygon_2_edge_iterator<Traits_, Container_>(
container, first_vertex + n);
operator-=(difference_type n) {
return (*this) -= n;
operator-(difference_type n) const {
container, first_vertex - n);
difference_type
operator-(const Polygon_2_edge_iterator<Traits_, Container_>& a) const {
return first_vertex - a.first_vertex;
Segment_2 operator[](int n) const {
return *Polygon_2_edge_iterator<Traits_, Container_>(
container, first_vertex+n);
bool operator<(const Polygon_2_edge_iterator<Traits_, Container_>& a)
const
return first_vertex < a.first_vertex;
bool operator>(const Polygon_2_edge_iterator<Traits_, Container_>& a)
const
return first_vertex > a.first_vertex;
bool operator<=(const Polygon_2_edge_iterator<Traits_, Container_>& a)
const
return first_vertex <= a.first_vertex;
bool operator>=(const Polygon_2_edge_iterator<Traits_, Container_>& a)
const
return first_vertex >= a.first_vertex;
distance_type(const Polygon_2_edge_iterator<Traits_,Container_>&)
{ return Container_::difference_type(); }
typename Traits_::Segment_2*
value_type(const Polygon_2_edge_iterator<Traits_,Container_>&)
{ return (typename Traits_::Segment_2 *)(0); }
// implementation
// I don't know how to implement the following function:
// template <class Traits_, class Container_>
// inline
// Polygon_2_edge_iterator<Traits_, Container_>
// operator+(Container_::difference_type n,
// Polygon_2_edge_iterator<Traits_, Container_>& a)
// { return a+n; }
CGAL_END_NAMESPACE
#endif
