cgal-discuss - Re: [cgal-discuss] iterator_distance won't compile
  • To:
  • Subject: Re: [cgal-discuss] iterator_distance won't compile
  • Date: Thu, 25 Sep 2008 14:25:12 -0700
The new file not only compiles, it works! (That is, the one case in my test program produces the correct result - ship it!)
Thank you very much for the rapid turn-around.
Roger House
Sylvain Pion wrote:
Roger House a écrit :
Sylvain:
Thank you for your reply. I looked at Polygon_2_edge_iterator.h, but I don't see where
"const" might be inserted. Below is an excerpt from that file which would seem to be the place to make changes. If you can make the required changes in a reply, I will see if they fix the iterator_distance problem.
Here is the patched file attached.
