cgal-discuss - [cgal-discuss] validity of the robustness demo
  • To:
  • Subject: [cgal-discuss] validity of the robustness demo
  • Date: Thu, 25 Sep 2008 22:07:27 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=subject:from:to:content-type:date:message-id:mime-version:x-mailer :content-transfer-encoding; b=KUPOJGEFgGw/scPcO5SKfOZ5LYIgLaPTkq5jpEPcuh3BE3ogvAw7ayrq0X8CDcvLTS oAxT7rW7pLHdQ7YxoOTJQNOCKoJHXmQSX6RINnMazRmmrj5V2rPRjkTyDkQvKwFkakU2 5vVefsilXPLOgZT6mpw3TQPZUhGU9imy/LghE=
Hi
I've been tampering with the intersection points on segments demo, and
would like to be verified of its validity as only 1-3 of 2000-3000
constructed intersection-points are found to lie on the segments.
I'm familiar with the Robustness issue, so I know it's due to the
underlying data types and the arithmetic used on them -- I've even
traced the primitives used in construction and in the predicate -- but
in: Invited Lecture: Real Numbers and Robustness in Computational
Geometry, the stated numbers from the robustness demo in CGAL 2.x is 20%
and not 0.05%-0.1%.
Further, I've altered the code so that an 'X' will mark the spot of the
intersection-point(s) that was(were) found to lie on the intersection,
and it is often nowhere near any intersection -- though this might be
due to an error from my part as when drawing the point I do:
*widget << (*fip)
where *fip is of type CartesianDouble::Point_2 (resp.
CartesianFloat::Point_2) and not C_double::Point_2 (resp.
C_real::Point_2) as is otherwise used in the file robustness.cpp.
Hope you can help!
Best regards
Jens
  • [cgal-discuss] validity of the robustness demo, Jens Rasmussen, 09/25/2008
