- To:
- Subject: Re: [cgal-discuss] Vertex_handle and "operator->"
- Date: Tue, 07 Oct 2008 22:32:38 +0200
Hello Fernando,
Hello Eivind,
Speaking of Vertex_handle; am I the only one to mix up '.' and '->' with Vertex_handle?>
[snip]>
Using '*' and '->' at the same time on a variable (which is not a pointer type) looks "wrong" in my eyes>
How about:
std::list< Some_iterator > objects ;
Or in the upcoming version of C++
std::list< std::shared_ptr<someobj> > objects ;
With those you also need '->' instead of '.'
Ok, I have neither had to deal with lists of iterators, nor used the upcoming version of C++, but I understand that this is more common than what I am used to.
Can I generally assume that all types that end with "_handle" in CGAL implements an "operator->"?Yes.
Great! :)
Handles *refers* to other objects, just like iterators and pointers, so they provide indirect access via '->'
It is idiomatic to expect the left side of '->' to possibly refer to a non-existing object (say a past-the-end iterator or a null pointer), while that would be quite surprising for the left side of a '.'.
A default constructed handle, for instance, does not refer to any object at all:
void use_vertex ( Vertex_handle v )
Vertex_handle null ;
if ( v != null )
// 'v' corresponds to a valid vertex so go ahead and use it.
It all makes a lot of sense. Thanks for explaining.
If I had been able to find all this information by searching for "Vertex_handle" in the documentation index, then I couldn't have been happier. I guess I could have searched for "Handle" instead, then I would at least have found the link that Andreas just sent to the list. I'll try to be more creative next time I search the index :)
However, letting Vertex_handle have it's own page in the documentation makes sense to me, since it's such a basic part of the triangulation library.
Thanks again,
Eivind
- [cgal-discuss] Vertex_handle and "operator->", Eivind LM, 10/07/2008
- Re: [cgal-discuss] Vertex_handle and "operator->", Fernando Cacciola, 10/07/2008
- Re: [cgal-discuss] Vertex_handle and "operator->", Eivind LM, 10/07/2008
