cgal-discuss - Re: [cgal-discuss] Vertex_handle
  • To:
  • Subject: Re: [cgal-discuss] Vertex_handle
  • Date: Wed, 08 Oct 2008 09:24:40 +0200
And I have to correct myself again. The documentation sniplet about the
iterators and handles is in the manual of the chapter on 2D triangulations
and not in the chapter of 3D triangulations, which you use.
We will fix that,
andreas
Andreas Fabri wrote:
There is probably space to improve the manual, but the notion of "Handle" IS documented, and
not only at obscure and hard to find places, but right in the beginning of the user manual of the
triangulation chapter.
25.4.1 Description
The class Triangulation_2<Traits,Tds> serves as a base class for the other 2D triangulations classes and implements the user interface to a triangulation.
The vertices and faces of the triangulations are accessed through handles, iterators and circulators. A handle is a model of the concept Handle which basically offers the two dereference operators * and -> . A circulator is a type devoted to visit circular sequences. Handles are used whenever the accessed element is not part of a sequence. Iterators and circulators are used to visit all or parts of the triangulation.
Source: http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Triangulation_2/Chapter_main.html
So I insist, please read the manual, and note that there is no need to read all pages.
The manual is broken down in parts, which are broken down in chapters, which consist
of a User Manual, many of them with examples, and a Reference Manual.
best regards,
andreas
Juan Pablo Carbajal wrote:
Thanks a lot!
Extremely useful!
JPi
On Tue, Oct 7, 2008 at 8:52 PM, Andreas Fabri
wrote:
Dennis Endt wrote:
Andreas Fabri schrieb:
Dennis Endt wrote:
Hi,
thats my Problem:
/typedef CGAL::Simple_cartesian<double> SK;
typedef CGAL::Filtered_kernel<SK> FK;
struct K : public FK {};
typedef K::Point_3 dPoint;
typedef CGAL::Delaunay_triangulation_3<K> Triangulation;
typedef Triangulation::Vertex_handle Vertex_handle;
Triangulation T;
list<Vertex_handle> vertices; // vector to hold the points of the convex
hull
T.incident_vertices(T.infinite_vertex(), back_inserter(vertices)); //
get the points from Delaunay/
Can anyone plz tell how I get access to the points corresponding to the
vertex_handles? It is very urgent.
I tried everything so far...it cannot be so difficult ;)
Best Dennis
for(list<Vertex_handle>::iterator it = vertices.begin();
it != vertices.end();
++it){
std::cout (*it)->point() << std::endl;
Thanks a lot! :)
I only forgot to set the brackets. It can be so easy :)
Best
Dennis
And here comes the "official" link
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Handle_ref/Concept_Handle.html
andreas
