- To:
- Subject: [cgal-discuss] Vertex_handle and "operator->"
- Date: Tue, 07 Oct 2008 19:37:40 +0200
Speaking of Vertex_handle; am I the only one to mix up '.' and '->' with Vertex_handle?
I'm used to having
std::list< MyObject > objects;
std::list< MyObject >::iterator it = objects.begin();
and when I dereference the iterator, then I'm getting a MyObject back, so I would call
(*it).do_something(); // using '.' instead of '->' since (*it) is MyObject
However, if I have
std::list< Vertex_handle > vertices;
std::list< Vertex_handle >::iterator it = vertices.begin();
then I need to do
(*it)->point(); // using '->' instead of '.'
Using '*' and '->' at the same time on a variable (which is not a pointer type) looks "wrong" in my eyes, so I very often automatically write
(*it).point(); // error
The compiler error I would expect in this case is
request for member ‘point’ in ‘* it’, which is of non-class type [...]
but instead I get
[...] has no member named ‘point’
which was very confusing in the beginning. The crucial point is that Vertex_handle implements "operator->", but I didn't realize this until I had a look in the source. Has anyone else been confused by the same thing?
Can I generally assume that all types that end with "_handle" in CGAL implements an "operator->"?
Eivind
- [cgal-discuss] Vertex_handle and "operator->", Eivind LM, 10/07/2008
- Re: [cgal-discuss] Vertex_handle and "operator->", Fernando Cacciola, 10/07/2008
- Re: [cgal-discuss] Vertex_handle and "operator->", Eivind LM, 10/07/2008
