- To:
- Subject: Re: [cgal-discuss] Edge/Facet Iterator
- Date: Mon, 13 Oct 2008 20:57:38 +0200
Dennis Endt wrote:
Hi,
I already study the manual but I didn`t find a solution.
Hi Dennis,
It's again documented at a place hard to find:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/TriangulationDS_3_ref/Concept_TriangulationDataStructure_3.html#Cross_link_anchor_986
andreas
Here is what I know:
Finite_vertices_iterator iv:
(*iv).point() to get a point
Finite_facets_iterator it:
it->first->vertex(i)->point() to get a point
Finite_edges_iterator ie:
Nothing found: I tried ie->second.point() and sth different like this.
But what is the right one?
Best,
Dennis
Monique Teillaud schrieb:
Hi,
I saw several answers to your previous questions on this list already.
There was at least one other similar question asked in parallel, which
was answered too.
Somebody told you already how to get a point from a vertex or a
vertex_handle.
There are typedefs in the manual for
Edge: triple<cell_handle,int,int>
Facet: pair<cell_handle,int>
Everything is detailed in the reference manual of the 3d triangulation
chapter (with links to the 3D triangulation data structure chapter
when appropriate)
Having a look at the manual would help *a lot*.
Best,
Monique
Dennis Endt wrote:
Hi,
I`ve a few questions and I hope anyone could help me soon.
typedef CGAL::Simple_cartesian<double> SK;
typedef CGAL::Filtered_kernel<SK> FK;
struct K : public FK {};
typedef K::Point_3 Point_3;
typedef CGAL::Delaunay_triangulation_3<K> Triangulation;
*Triangulation::Finite_edges_iterator*
How can I read out the points of an edge or the edge itself?
Is there any typedef for an edge regarding to the typedef for a point
above?
*Triangulation::Finite_facets_iterator*
If there is any typedef for an edge, how can I read out the edges of a
facet?
Best,
Dennis
- [cgal-discuss] Flipping inside a triangulation, Daniel Duque Campayo, 10/13/2008
- [cgal-discuss] Edge/Facet Iterator, Dennis Endt, 10/13/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Monique Teillaud, 10/13/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Dennis Endt, 10/13/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Laurent Rineau, 10/13/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Andreas Fabri, 10/13/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Manuel Caroli, 10/14/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Dennis Endt, 10/14/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Andreas Fabri, 10/14/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Monique Teillaud, 10/15/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Olivier Devillers, 10/15/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Dennis Endt, 10/15/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Daniel Duque Campayo, 10/15/2008
