- To:
- Subject: Re: [cgal-discuss] Edge/Facet Iterator
- Date: Wed, 15 Oct 2008 10:13:25 +0200
Dennis Endt a écrit :
Hi Andreas,
I read the manual for another time and it became clear how I can get a
triangle of a facet. I think I understand how you define the geometry
and how I can work with them.
But I miss the edges of a triangle. Can I only read out the points?
It must be clear that you do not "read the triangle" from the triangulation.
The triangle you get is constructed on the fly when you ask for it.
From the manual I get (but you said that you looked at it ;-)
Triangle t.triangle ( Face_handle f) Returns the triangle formed by the three vertices of f.
Precondition: The face is finite.
Segment t.segment ( Face_handle f, int i) Returns the line segment formed by the vertices ccw(i) and cw(i) of face f.
Precondition: 0 i 2. The vertices ccw(i) and cw(i) of f are finite.
Segment t.segment ( Edge e) Returns the line segment corresponding to edge e.
Precondition: e is a finite edge
Segment t.segment ( Edge_circulator ec) Returns the line segment corresponding to edge *ec.
Precondition: *ec is a finite edge.
Segment t.segment ( Edge_iterator ei) Returns the line segment corresponding to edge *ei.
Precondition: *ei is a finite edge.
Point t.circumcenter ( Face_handle f) Compute the circumcenter of the face pointed to by f. This function is available only if the corresponding function is provided in the geometric traits.
thus you can get Segment corresponding to an edge (but this segment is constructed when you ask for it)
The only geometry stored in the trainagulation is a point for each finite vertex
- Re: [cgal-discuss] Edge/Facet Iterator, (continued)
- Re: [cgal-discuss] Edge/Facet Iterator, Monique Teillaud, 10/13/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Dennis Endt, 10/13/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Laurent Rineau, 10/13/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Andreas Fabri, 10/13/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Manuel Caroli, 10/14/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Dennis Endt, 10/14/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Andreas Fabri, 10/14/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Monique Teillaud, 10/15/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Olivier Devillers, 10/15/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Dennis Endt, 10/15/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Daniel Duque Campayo, 10/15/2008
- Re: [cgal-discuss] Edge/Facet Iterator, Monique Teillaud, 10/14/2008
