cgal-discuss - Re: [cgal-discuss] Edge/Facet Iterator
  • To:
  • Subject: Re: [cgal-discuss] Edge/Facet Iterator
  • Date: Wed, 15 Oct 2008 12:04:46 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject:references :in-reply-to:content-type:content-transfer-encoding; b=eAP2MNw+YA5o86Y/I3sVuBuytYsBRL2aVMN/T89QngSUv2OlWj2Y8XHtZujBJQlcuU lddytAS2GYR14UqMX4Cl8y2uGoX+PMolnWE8mOLMGsxZC9s40KfygTlZSZAdN+k5eXyV GInMoJ8wuHVlekl+e4QlUwA5Q7cM2BT+XatLE=
Hi,
thanks for your reply.
That`s what I`m looking for:
Segment t.segment ( Face_handle f, int i)
But this doesn`t exist. I don`t find it in the maunal and the compiler
only gives me two possibilities to define a segment:
Segment t.segment( Edge e)
Segment t.segment( const Cell handle c, int i, int j)
So plz tell me how can I get the edges/segments of a face where the face
should be a triangle? A small example woulb be very nice.
Best,
Dennis
Olivier Devillers schrieb:
> Dennis Endt a écrit :
>> Hi Andreas,
>> I read the manual for another time and it became clear how I can get a
>> triangle of a facet. I think I understand how you define the geometry
>> and how I can work with them.
>> But I miss the edges of a triangle. Can I only read out the points?
> It must be clear that you do not "read the triangle" from the
> triangulation.
> The triangle you get is constructed on the fly when you ask for it.
> From the manual I get (but you said that you looked at it ;-)
> Triangle t.triangle ( Face_handle f) Returns the triangle
> formed by the three vertices of f.
> Precondition: The face is finite.
> Segment t.segment ( Face_handle f, int i) Returns the line
> segment formed by the vertices ccw(i) and cw(i) of face f.
> Precondition: 0 i 2. The vertices ccw(i) and cw(i) of f are finite.
> Segment t.segment ( Edge e) Returns the line segment
> corresponding to edge e.
> Precondition: e is a finite edge
> Segment t.segment ( Edge_circulator ec) Returns the line
> segment corresponding to edge *ec.
> Precondition: *ec is a finite edge.
> Segment t.segment ( Edge_iterator ei) Returns the line segment
> corresponding to edge *ei.
> Precondition: *ei is a finite edge.
> Point t.circumcenter ( Face_handle f) Compute the circumcenter
> of the face pointed to by f. This function is available only if the
> corresponding function is provided in the geometric traits.
> thus you can get Segment corresponding to an edge (but this segment is
> constructed when you ask for it)
> The only geometry stored in the trainagulation is a point for each
> finite vertex
