cgal-discuss - Re: [cgal-discuss] Edge/Facet Iterator
  • To:
  • Subject: Re: [cgal-discuss] Edge/Facet Iterator
  • Date: Tue, 14 Oct 2008 16:25:45 +0200
I would like to stress again the fact that all this is written explicitely in the manual --- ref manual, but also user manual, which introduces basic choices of representation, to be read before starting.
Also, the stp::pair used to represent a facet is not specific to CGAL.
The triple used for edge is a natural generalization of a pair.
Manuel Caroli wrote:
Hi Dennis,
Dennis Endt wrote:
Last Question:
Finite_facets_iterator it:
I would like to get the edges of a facet. What`s the correct method for
this?
I don't think this is the right question to ask. As you will have figured out from the manual neither edges nor facets are stored explicitly in the data structure.
So an edge is nothing but a triple (Cellhandle c, int i, int j) where c->vertex(i) and c->vertex(j) are the vertices connected by the edge.
So if you want to know these endpoints this is the answer to your question.
Be aware of the strong separation between geometric and combinatorial primitives at this point: vertices, edges, facets, and cells are purely combinatorial primitives. That is also the reason why they don't contain geometric information like e.g. coordinates, and why you do not find them in the kernel. On the other hand you have points, segments, triangles, tetrahedra etc. as geometric primitives.
hope this helps
Manuel
