cgal-discuss - Re: [cgal-discuss] Re: Implementing custom version of CGAL::refine_Delaunay_mesh_2()
  • To:
  • Subject: Re: [cgal-discuss] Re: Implementing custom version of CGAL::refine_Delaunay_mesh_2()
  • Date: Thu, 16 Oct 2008 11:49:30 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references:x-google-sender-auth; b=bZMMagxYmtElcvN6+obk3QfTERHP0GVGfkf1tBokT2AI8lbqnZcyQyYBc7mO8MIQNl sAjrMYh8zw2QEei3Mb1lGggADgChHLF2bvvPt9WRtlo2dn/NA+OptPEUBEL+3A31+7J4 MnMBuM1b6l2HV7vCqyfec0I0ImCm//2bUgf5w=
Thank you very much for your help. I was able to refactor the code and
make my own Delaunay_mesher_2 in my own namespace with all the
supporting classes. I am still working on implementing the
private_test_point_conflict_impl() ...
Is there a paper, technical report or a webpage that explains the
algorithm used in CGAL::refine_Delaunay_mesh_2?
On Sun, Oct 12, 2008 at 6:12 PM, Mariette Yvinec
wrote:
> too difficult ...
> on the theoretical side, our meshing algorithm requires the contrained
> edges to be refined
> in subedges having the Gabriel property, meaning that their diametral ball
> is empty of mesh vertices.
> This is important because it guarantees that Steiner vertices are ony
> inserted inside
> the domain which is crucial fr termination. Your will have to drop that
> requirement at least fro some edges.
> Therefore if you want to avoid that the meshing algorithm goes on inserting
> Steiner vertices for ever
> furthter and further away, make sure that the domain is surrounded by a
> bounding box
> the edges of which will be refined on Gabriel edges
> on the code sides, you will have to change several things.
> If I am right, these things will be merely
> in the class Refine_edge.h and/or Refine_edge_base.h
> all related to test_confilct_point***** :
> no longer derive from No_private_test_point_conflict
> add a private_test_point_conflict
> test_point_conflict_from_superior_impl
> M. Hazegh wrote:
>> I wonder if my question was too naive or too difficult?
>> On Fri, Oct 10, 2008 at 2:21 PM, M. Hazegh
>> wrote:
>>> Anybody can comment on this please?
> Mariette Yvinec
> Geometrica project team
> INRIA Sophia-Antipolis
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
